Recommedations: Printing job attachments
Can anyone give me recommendations on SW that will print job attachments.
You want documents that are attached to a job to print during a specific business process?
Or just “Print every attachment related to job XYX…” ?
Either way, I think it would depend on a lot of things like the format the attachmnet is in (PDF, XLSX, DOX, etc…) the output device, output specific settings (like shrinking oversized drawings to fit the printer)
A hack could be made where a BAQ pulls the file names (with paths) and the BAQ report creates a script that launches the appropriate program/viewer for each doc, with the print command on the command line.
I believe Epicor has an extended solution for printing job attachments.
Brad
