What, if any exists, is the setup to accomplish the receipt of 10 WIGETKIT and the system will update the WKP1-3 with their respective received quantities?
There is no āgoodā solution in my opinion. Itās all just workarounds. There are some suggested in that post I linked. That was posted just within the last day or 2.
I like your idea. Some questions that I would have isā¦
If the PO is written as a kit, how do you receive something other than what was on the PO?
How do you break up the cost?
There are transactions that are going to be made based on this. What do they look like?
Iām asking because I just made that post a few days ago and my only solution thus far was to manually create a job with co-parts that consumes the kit and generates the sub-components as co-parts. Iāve never messed with co-parts before so Iām not even sure how viable it is.
Donāt know yet just spitballing my first idea (usually a simple one) as for your points/questions, not sure yet, but thank you for thinking through gotchas on my idea If you think of any others, please let me know, I have only been asked this question about 45 min ago, so this was as I said the first idea that came to my mind.
Iād think the desired solution would mirror a Sales Kit.
When you enter a SK on an order, it actually generates hidden lines for each component. Settings (per each SK) allow for expanding those lines out during shipping and/or invoicing.
A PO Kit (POK) entered on a PO line would create hidden lines for the components. During receipt there could be an option to automatically breakup the POK so the individual components (and hence their hidden PO lines) would be received. Alternately the POK could be required to go through a process (like inspection) that someone actually separates the POK into components.
Edit
What happens if you try to enter an SK part# on a PO? And what about RMAās? How do they handle returns of SKās?
Iāve always wanted to see a Disassembly Job. You issue an assembly to the job (STK-MTL, INS-MTL, etc.) and then move the individual components to the regular demand types (MTL-STK - Stock, MTL-MTL - Job, or MTL-CUS - Customer).
During the āGet Detailsā phase, the operator could get the components from a Method or a Job. The user should also have the option to alter the quantities since some parts may not be salvaged (glues, seals, etc.) It should work with purchased items too, as long as there is a BOM.
