Receipt errors and returns
Yes, that's what I am saying, to the best of my knowledge. I believe this
would be true for both inventory and other.
The only other scenario that I can imagine that would prevent "un-receiving"
a PO receipt is one where the items were received to a job and the job was
subsequently closed.
Regards,
Scott
Sent: Friday, January 07, 2005 9:01 AM
Subject: [Vantage] Re: Receipt errors and returns
Scott,
Thanks for the answer to the second part of my post. (What a great
user group.) Although a huge portion of our stuff is inspected upon
receipt, are you saying that errors on non-inspected items can
be "un-received" until the invoice is entered. Would this be true
for both inventoried and expensed (no part number) items?
TIA
Michael Randolph
Purchasing Manager
American Magnetics, Inc.
--- In vantage@yahoogroups.com, "Lepley, Scott A." <sal@m...> wrote:
> Michael,
> You should be able to "un-receive" the PO line item simply by
deleting the erroneous line from the vendor packing slip. However, you will
not be able to delete the packing slip line if an invoice has been entered
against it in Accounts Payable or if the items were received to and
processed
through inspection processing.
> Regards,
> Scott
> From: ami_miker [mailto:michael.randolph@a...]
> Sent: Wednesday, January 05, 2005 3:39 PM
> Subject: [Vantage] Receipt errors and returns
> We are about a month into 6.1 and run into a receiving error. The
> wrong line on a PO was received, but we are unable to "un-
receive".
> Can this be done?
> Also, how are you returning items from stock to the vendor? The
> most common example would be defective parts not discovered during
> incoming inspection. We are able to use the RMA and DMR process
to
> adjust the inventory quantity and value, but if we expect
> replacement parts, what do we do?
> Suggestions??
> Michael Randolph
> Purchasing Manager
wrong line on a PO was received, but we are unable to "un-receive".
Can this be done?
incoming inspection. We are able to use the RMA and DMR process to
Suggestions??
Michael Randolph
Purchasing Manager
I think you can enter a non-conformance for the discovered bad parts and
then reject them for credit and assign a supplier for the DMR.
Frank Zeigafuse
Innovative Office Products
General Manager
Direct Phone: 610-559-6369
Email: fzeigafuse@...
Can this be done?
Suggestions??
Michael Randolph
Purchasing Manager
Yahoo! Groups Links
<www.LCDarms.com> -- Ergonomic mounting solutions for monitors and keyboards
This e-mail is from Innovative Office Products, Inc. but expresses the views of the sender and not necessarily the views of the company. The email and any files transmitted with it are confidential to the intended recipient at the e-mail address to which it has been addressed. It may not be disclosed or used by any other than that addressee, nor may it be copied in any way. If received in error, please delete and notify the sender via e-mail or sales@... quoting the name of the sender. Messages sent via this medium may be subject to delays, non-delivery and unauthorized alteration. This e-mail has been prepared using information believed by the author to be reliable and accurate. Unless expressly stated otherwise, this e-mail does not form part of a legally binding contract or agreement between recipient and Innovative Office Products, Inc.
Warning: Although Innovative Office Products, Inc. has taken reasonable precautions to ensure no viruses are present in this email, we cannot accept responsibility for any loss or damage arising from the use of this email or attachments. It is, therefore, your responsibility to scan attachments (if any).
Frank - Thanks for the response. After following up on your note,
there is a place to process a return to the supplier, which offers
the option of creating a packing slip and / or a debit memo. (I was
misinformed by someone internally.) I had hoped that the supplier
could somehow ship any replacement parts against the original PO
line, but doesn't seem possible (or at least easy) so we will start
issuing new PO's.
Thanks again.
Michael Randolph
Purchasing Manager
--- In vantage@yahoogroups.com, "Frank Zeigafuse" <fzeigafuse@l...>
parts and
> Frank Zeigafuse
> General Manager
> Email: fzeigafuse@L...
receive".
> Can this be done?
to
> Suggestions??
> Michael Randolph
> Purchasing Manager
must have
Builder and
> Yahoo! Groups Links
and keyboards
sales@L... quoting the name of the sender. Messages sent via this
Products, Inc.
Michael,
You should be able to "un-receive" the PO line item simply by deleting the
erroneous line from the vendor packing slip. However, you will not be able
to delete the packing slip line if an invoice has been entered against it in
Accounts Payable or if the items were received to and processed through
Regards,
Scott
Can this be done?
Suggestions??
Michael Randolph
Purchasing Manager
Scott,
TIA
Michael Randolph
Purchasing Manager
> Michael,
deleting the
not be able
against it in
through
> Regards,
> Scott
receive".
> Can this be done?
to
> Suggestions??
> Michael Randolph
> Purchasing Manager
