Receipt entry in Epicor 9.05.702A. Does anyone's "arrived lines
I know…there have been a lot of times over the years where I have caught Epicor documentation saying the wrong thing…my worst situation was the very first time I did a physical inventory in version 5 or 6, we voided a lot of tags only to be told once you void one tag, then all tags for that part number were technically voided!  And even though I had NOT posted I could not change them…$15MM inventory down the drain…I learned NEVER to depend on their documentation…..I test first if I can….or depend on this group!
All you can do is find it and tell Epicor to fix it….they are actually good about that.
Manasa
Sent: Wednesday, March 09, 2016 11:45 AM
Subject: RE: [Vantage] RE: Receipt entry in Epicor 9.05.702A. Does anyone's "arrived lines" show up in the dialog box when you select a PO and Packing slip to receive from?
Thanks Manasa, it’s just frustrating that the actual MANUAL shows that it works differently and is wrong….
Sent: Wednesday, March 09, 2016 10:36 AM
Subject: [Vantage] RE: Receipt entry in Epicor 9.05.702A. Does anyone's "arrived lines" show up in the dialog box when you select a PO and Packing slip to receive from?
Yep that is how we also did it, we picked and chose through the Mass Receipt area.  Use the check boxes on the far left to pick and choose your lines.  The system moves them from the top section to the bottom section.
Manasa
Sent: Wednesday, March 09, 2016 10:52 AM
The be able to see all the open lines, we do the Mass receipt and select the lines that are coming in.  This is the only way I know of.
We went from Vantage 6 to Epicor9.
From: vantage@yahoogroups.com [vantage@yahoogroups.com]
Sent: Wednesday, March 09, 2016 7:23 AM
Subject: [Vantage] Receipt entry in Epicor 9.05.702A. Does anyone's "arrived lines" show up in the dialog box when you select a PO and Packing slip to receive from?
We upgraded from Vantage 8 to Epicor 9 and appears that we lost the functionality when we go into Receipt Entry, and enter a PO and packing slip, we do not get ANY “arrived” lines that we can choose from to receive against.  We can either receive a line “manually” if we go into “Stock, Job Material, Other Material, etc” tabs and then select “new” or we can go into the “mass receipt” deal and work there but it was so much easier in Vantage 8.  The strange thing is that in the 9.05 manual, it blatantly says that the application should show the arrived lines for the receipt when we select the PO and Packing slip (just as Vantage 8 did).  I just got off the phone with Epicor support and they told me that NO, it doesn’t work that way anymore and we have to use Mass Receipt to auto-receive but the picture in the actual Epicor 9.05 user manual on page 561 shows it the way it used to work in Vantage 8.  I’m conflicted on whether I need to fight Epicor on this or it truly just doesn’t work anymore.  I’m just wondering why they even have a tab in the grid on receipt entry that says “Arrived Lines” if nothing ever populates it.  Can someone on Epicor 9.05.702A verify on their system that what Epicor is telling me is the truth?
Best regards
Mike Abell
IT Manager
Flexial Corporation
a company of BOA Group
1483 Gould Drive, Cookeville, TN 38506, USA
Phone:    +1 931 432 8408
Fax:        +1 931 432 1889
Mail:        mabell@...
Website:  http://www.flexial.com
               http://
www.boagroup.com
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
IMPORTANT NOTICE FROM API: This communication, including any attachments, contains information that may be confidential or privileged and is intended solely for the entity or individual to whom it is addressed. If you are not the intended recipient, please contact the sender immediately and delete this message. Any unauthorized disclosure, copying or distribution of this message is strictly prohibited.
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
Disclaimer
Manasa
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
Disclaimer
Manasa
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
Disclaimer
