Re-Mapping of Chart of Accounts
This was one of the reasons that we started with a clean data base in
our conversion to 8.0 on 1/1/08. We were then able to create 3 digit vs
2 digit department numbers to be incorporated into the chart of accounts
layout, as well as, cleaning up all of our master files in which we only
brought over active data.
We purchased the run time version of Pervasive and then had to purchase
templates (excel) from Epicor that have the proper layout of data. We
then exported our info out of 6.1 to excel templates, we cleaned out any
data we did not want to bring forward, like inactive part numbers,
suppliers, customers, etc. and then imported the info into 8.03.
It was not an easy process but when we got through it, it made for a
nice and clean database. We also brought a version of 6.1 forward
through normal conversion which we call Historical and removed all
rights to do anything but view trackers to make historical data
available to users.
Paul E. Pachniak
Accounting Manager
Ace Precision Machining Corporation
W146 N5714 Enterprise Avenue
Menomonee Falls, WI 53051
Phone: 262-252-4003 Ext. 1114
Fax: 262-252-4974
Email: paul.pachniak@...
WWW: http://www.aceprecision.com
NOTICE: THIS MESSAGE CONTAINS THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF ACE PRECISION MACHINING CORP. If you are an unintended recipient, immediately (1) delete all copies of this message and any attachments, and (2) contact the sender. If you are an intended recipient, you are prohibited from deleting or obstructing this or any other Ace Precision Machining Corp. proprietary or confidentiality designation that appears on this message or any attachments. All recipients are prohibited from reproducing, publishing or disclosing the contents of this message and any attachments to others, unless you first request and receive written permission from Ace Precision Machining Corp.
