#1 Special to V8 is that all reports get saved for as long as you
designate the number of days in the "archive period" when you run the
report (print or preview)
#2 The reports are stored (as a .txt file) in a directory called
mfgsysdata/reports/username either on the client or the server depending
on the install.
#3 So these can be opened from excel using import wizard
Tony Topping
Senior Consultant
COGITA(r)
Phone: +64 9 261-1411 x710
Fax: +64 9 261-0799
MOB: +64 21 750 873
eMail: tony.topping@...
URL: www.cogita.com <http://www.cogita.com/>
more, better, different(tm)
on the install.
Tony Topping
Senior Consultant
COGITA(r)
Fax: +64 9 261-0799
MOB: +64 21 750 873
