rcdaXXXXX files taking up major storage on Epicor 9 server. Can
A restart is often the only way to free those up.
Server should be restarted periodically anyway, once a month at a minimum if not at least once a week with installation of updates.
On Mon, Aug 8, 2016 at 4:21 PM, 'Chang, Chia' cchang@... [vantage] <vantage@yahoogroups.com> wrote:
We run into instances where the temp files are locked “because the file is opened in Progress client” from months ago that we aren’t able to delete until we do a restart.
Â
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups. com]
Sent: Thursday, February 11, 2016 3:18 PM
Subject: [Vantage] RE: rcdaXXXXX files taking up major storage on Epicor 9 server. Can these be deleted???
Â
Â
Here is a full file someone posted.
Â
:: Will scan the directory and delete any file older than XX days
:: The xx being whatever value comes after the -d flag
:: Clear General EpicorData files generated by the server
forfiles -p "C:\Epicortemp" -d -15 -m Assign* -c "Cmd /c del Echo @Path"
forfiles -p "C:\Epicortemp" -d -1 -m baq* -c "Cmd /c del Echo @Path"
forfiles -p "C:\Epicortemp" -d -15 -m bfc* -c "Cmd /c del Echo @Path"
forfiles -p "C:\Epicortemp" -d -15 -m bpm* -c "Cmd /c del Echo @Path"
forfiles -p "C:\Epicortemp" -d -15 -m BusEntity* -c "Cmd /c del Echo @Path"
forfiles -p "C:\Epicortemp" -d -15 -m COAL* -c "Cmd /c del Echo @Path"
forfiles -p "C:\Epicortemp" -d -7 -m DBI* -c "Cmd /c del Echo @Path"
forfiles -p "C:\Epicortemp" -d -15 -m GLBCOA* -c "Cmd /c del Echo @Path"
forfiles -p "C:\Epicortemp" -d -15 -m GLJrn* -c "Cmd /c del Echo @Path"
forfiles -p "C:\Epicortemp" -d -7 -m lbi* -c "Cmd /c del Echo @Path"
forfiles -p "C:\Epicortemp" -d -5 -m rcd* -c "Cmd /c del Echo @Path"
forfiles -p "C:\Epicortemp" -d -15 -m RestrictFcts* -c "Cmd /c del Echo @Path"
forfiles -p "C:\Epicortemp" -d -15 -m srt* -c "Cmd /c del Echo @Path"
forfiles -p "C:\Epicortemp" -d -15 -m trp* -c "Cmd /c del Echo @Path"
Â
:: Clear User Specific files that linger by user
forfiles -p "C:\Epicortemp\Reports" /s -d -90 -m *.xml -c "Cmd /c del Echo @Path"
forfiles -p "C:\Epicortemp\Reports" /s -d -90 -m *.txt -c "Cmd /c del Echo @Path"
Â
:: Clear User Specific bat files that linger by user
forfiles -p "C:\Epicortemp\Reports" /s -d -15 -m *.bat -c "Cmd /c del Echo @Path"
forfiles -p "C:\EpicorData" -d -15 -m Assign* -c "Cmd /c del Echo @Path"
forfiles -p "C:\EpicorData" -d -1 -m baq* -c "Cmd /c del Echo @Path"
forfiles -p "C:\EpicorData" -d -15 -m bfc* -c "Cmd /c del Echo @Path"
forfiles -p "C:\EpicorData" -d -15 -m bpm* -c "Cmd /c del Echo @Path"
forfiles -p "C:\EpicorData" -d -15 -m BusEntity* -c "Cmd /c del Echo @Path"
forfiles -p "C:\EpicorData" -d -15 -m COAL* -c "Cmd /c del Echo @Path"
forfiles -p "C:\EpicorData" -d -7 -m DBI* -c "Cmd /c del Echo @Path"
forfiles -p "C:\EpicorData" -d -15 -m GLBCOA* -c "Cmd /c del Echo @Path"
forfiles -p "C:\EpicorData" -d -15 -m GLJrn* -c "Cmd /c del Echo @Path"
forfiles -p "C:\EpicorData" -d -7 -m lbi* -c "Cmd /c del Echo @Path"
forfiles -p "C:\EpicorData" -d -5 -m rcd* -c "Cmd /c del Echo @Path"
forfiles -p "C:\EpicorData" -d -15 -m RestrictFcts* -c "Cmd /c del Echo @Path"
forfiles -p "C:\EpicorData" -d -15 -m srt* -c "Cmd /c del Echo @Path"
forfiles -p "C:\EpicorData" -d -15 -m trp* -c "Cmd /c del Echo @Path"
Â
forfiles -p "C:\EpicorData\Reports" /s -d -90 -m *.xml -c "Cmd /c del Echo @Path"
forfiles -p "C:\EpicorData\Reports" /s -d -90 -m *.txt -c "Cmd /c del Echo @Path"
Â
forfiles -p "C:\EpicorData\Reports" /s -d -15 -m *.bat -c "Cmd /c del Echo @Path"
Â
Miguel A. Santillan
Compass Manufacturing Systems
Â
Sent: Thursday, February 11, 2016 1:04 PM
Subject: [Vantage] rcdaXXXXX files taking up major storage on Epicor 9 server. Can these be deleted???
Â
Â
I have numerous files that start with rdca and then a 5 digit number on my server that are being created periodically and hundreds of megabytes in size. Can these safely be deleted?Â
Â
Best regards
Mike Abell
IT Manager
Flexial Corporation
a company of BOA Group
1483 Gould Drive, Cookeville, TN 38506, USA
Phone:Â Â Â +1 931 432 8408
Fax:Â Â Â Â Â Â Â +1 931 432 1889
Mail:Â Â Â Â Â Â Â mabell@...
Website:Â http://www.flexial.com
              http://
www.boagroup.com
Â
Â
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
Best regards
Mike Abell
IT Manager
Flexial Corporation
Phone:    +1 931 432 8408
Fax:        +1 931 432 1889
Mail:        mabell@...
Website:  http://www.flexial.com
               http://
www.boagroup.com
I have a batch file that deletes these files, it is ran on the task scheduler.
forfiles /p "E:\EPICORTEMP" /c "Cmd /c del Echo @Path"
If the file is being used it wont delete it.
Miguel A. Santillan
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
Disclaimer
Miguel A. Santillan
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
Disclaimer
Thanks so much Miguel, nice to know I can get rid of that stuff as it was REALLY taking up a lot of disk space….
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
Miguel A. Santillan
Best regards
Mike Abell
IT Manager
Flexial Corporation
Mail:        mabell@...
               http://
www.boagroup.com
Disclaimer
