RB report for G/L Income statement
Financial reports cannot be posted on egroups. In your financial designer
look at # of periods and period and year offsets. You can set these up for
prior periods and prior years so when you run a current period report it
will calculate prior periods and years if it is setup properly in the
designer and you do not have to change anything once you have this setup.
Sent: Monday, September 11, 2000 11:37 AM
To: vantage@egroups.com
Subject: RE: [Vantage] RB report for G/L Income statement
Would you please post this report.
Sent: Monday, September 11, 2000 10:28 AM
To: vantage@UUCP {vantage@egroups.com}
Jeff: I have done this in the financial reports
in Vantage. It is fairly simple to do however each
month you have to 'reset' the column's to include
the previous period which was the current period
last period. Kind of a pain. Unless someone else
knows of a better way ....
Jeff,
Have you looked into creating your required report in the Financial Report
Designer? At the last users' conference a class showed how it can be done.
I haven't done it on my own, but I could probably dig up the instruction
sheet they handed out at that session if you need it. Let me know, and I
can fax you a copy.
Nora Story
Spectra Technologies, Inc.
817-540-4475 ext 105
Jeff Kelly wrote:
I am looking for a report builder report that would produce an income
statement in columns for each period. Has anyone done this report that
they
would like to share?
Nora Story wrote:
> Jeff,
> can fax you a copy.
> Nora Story
> they
> We no longer allow attachments to files. To access/share Report Files, please go to the following link: http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try it, go to www.egroups.com, login and be sure to save your password, choose My Groups, choose Vantage, then choose Files. If you save the password, the link above will work the next time you try it.)
I would gratly appreciate a faxed copy of the instuction sheet also.
Thanks in advance.
John Zukowski
Perry Technology Corp.
fax # 860-738-2426
