We are adding an entry date field on QutoeDtl and we need to update it whenever a QuoteDtl row is added. My question is, should I look at all the different business objects that are called when creating a new line through the new line action, copy lines action, or duplicate quote action OR should I just use an in-transaction data directive on quote dtl and loop through the ttQutoeDtl table where RowMod == A and then update the field with DateTime.Now? OR… is there another way I am not thinking of?
I vote in-trans data directive with the added row check in an if-block (I think that’s the easiest route). I don’t THINK you would even need to loop through anything. I think it should fire for each new row and do your update each time.
