Somewhere in the trace you will see lines and lines of CDATA<field>change <value> info.
Â
Before that you should see the business object that was called and the method used.
Â
That is your path to triggering a BPM.
Â
Â
--- On Fri, 7/11/08, ofcwiz <DavidH@...> wrote:
Subject: [Vantage] Re: Quote to Sales Order Number01 field
Date: Friday, July 11, 2008, 1:47 PM
Kunal,
Here is what I get from the Trace.
CDATA[Key2 = 'App.QuoteEntry. CreateOrderWizar dForm']]> </parameter>
I don't see a way that this points to a BPM , BAM or Customization
solution.
DaveH
--- In vantage@yahoogroups .com, Kunal Ganguly <kunal_vantage@ ...> wrote:
> Use tracing options to see which function is called for the events
you trigger while in a form. Let me know if you don't know where this
is or have never used it.
> Thanks,
> Kunal
> ----- Original Message ----
> From: ofcwiz <DavidH@...>
> To: vantage@yahoogroups .com
> Sent: Thursday, July 10, 2008 9:43:15 AM
> Subject: [Vantage] Quote to Sales Order Number01 field
> Can anyone point me to the location of the code that is activated when
> the "Opportunity/ Quote Entry - Actions - Quote - Create Sales Order"
> menu item is clicked?
> Still having difficulty with moving the value of the 'Number01' Quote
> field to the 'Number01' Order field when converting Quote to SO.
> I would think this would have a simple solution. I have tried
> Customized field mapping, BPM, BAM. I have all these tools and no
> solutions.
> Thank you for any assistance,
> Dave
