when print previewing our customer quote we get an error in the system monitor im hoping someone also has had a similar issue
Program Ice.Services.Lib.RunTask raised an unexpected exception with the following message: RunTask: SysRowID
Stack Trace:
at System.Data.ProviderBase.FieldNameLookup.GetOrdinal(String fieldName)
at System.Data.SqlClient.SqlDataReader.GetOrdinal(String name)
at System.Data.SqlClient.SqlDataReader.get_Item(String name)
at Ice.Core.RptBase.OutputRelationDataWriter.WriteRowsForKeyValues(IDataReader reader, IList1 keyParameters, IDataSource relatedTable, Object[] keyValues) in C:\_Releases\ICE\ICE3.2.400.23\Source\Server\Internal\Lib\TaskLib\RptBase\OutputRelationDataWriter.cs:line 112 at Ice.Core.RptBase.OutputRelationDataWriter.WriteRowsForKeyValues(IDbCommand sqlCommand, IList
1 keyParameters, IDataSource relatedTable, Object[] keyValues) in C:_Releases\ICE\ICE3.2.400.23\Source\Server\Internal\Lib\TaskLib\RptBase\OutputRelationDataWriter.cs:line 84
at Ice.Core.RptBase.OutputRelationDataWriter.WriteRows(IDbCommand sqlCommand, IList1 keyParameters, IDataSource relatedTable, UniqueKeyCollection relationKeys) in C:\_Releases\ICE\ICE3.2.400.23\Source\Server\Internal\Lib\TaskLib\RptBase\OutputRelationDataWriter.cs:line 163 at Ice.Core.RptBase.OutputRelationDataWriter.WriteTable(DataSourceRelationship relationship, IDataSource relatedTable, DataColumnCollection keyColumns, UniqueKeyCollection keyValues) in C:\_Releases\ICE\ICE3.2.400.23\Source\Server\Internal\Lib\TaskLib\RptBase\OutputRelationDataWriter.cs:line 190 at Ice.Core.RptBase.OutputRelationDataWriter.WriteTables() in C:\_Releases\ICE\ICE3.2.400.23\Source\Server\Internal\Lib\TaskLib\RptBase\OutputRelationDataWriter.cs:line 44 at Ice.Core.RptBase.ReportDataBuilderBase.XMLClose() in C:\_Releases\ICE\ICE3.2.400.23\Source\Server\Internal\Lib\TaskLib\RptBase\ReportDataBuilderBase.cs:line 229 at Ice.Core.RptBase.ReportDatabaseBuilder.XMLClose() in C:\_Releases\ICE\ICE3.2.400.23\Source\Server\Internal\Lib\TaskLib\RptBase\ReportDatabaseBuilder.cs:line 91 at Ice.Core.RptTaskBase
1.XMLClose() in C:_Releases\ICE\ICE3.2.400.23\Source\Server\Internal\Lib\TaskLib\RptBase\RptTaskBase.cs:line 229
at Ice.Core.TaskBase`1.StartProcess(Int64 instanceTaskNum, String outputFileName) in C:_Releases\ICE\ICE3.2.400.23\Source\Server\Internal\Lib\TaskLib\TaskBase\TaskBase.cs:line 47
at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in C:_Releases\ICE\ICE3.2.400.23\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 98
at Ice.Hosting.TaskCaller.ExecuteTask() in C:_Releases\ICE\ICE3.2.400.23\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 57
at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in C:_Releases\ICE\ICE3.2.400.0\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 63
at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in C:_Releases\ICE\ICE3.2.400.0\Source\Server\Services\Lib\RunTask\RunTask.cs:line 592
