Every time we open a new quote, it opens on a second monitor… even if there isn’t one and I am not sure how to stop that. For people without a second monitor, they can’t see it…
thanks
thanks
ok fixed it… went into customizations and saved it on the first monitor… ugh… can be sooo specific.
Had this exact problem since I develop on 2 monitors.
My biggest pain was it took me several tries before realizing that after I made changes to position, I actually had to click another random component to get the change to stick before saving. Bug!
I was shown a workaround to get the screen back. It you right click on the task bar item, then click move, then hit an arrow button it will snap to your mouse so at least you can keep working. I have to do that on my surface a lot.
I had the same problem in 10.1.400, not sure if it still exists in 10.1.500.
I now keep the window I am customizing on the first monitor, and the toolbox on the second monitor.
Bryan DeRuvo
You can also use the Windows key and the arrows to move the active window.
