Quote Module in version 6.1
The final link for me was to create the part number in the part master, then go back to the quote and change the part number in the quote to be the same as the one I just created, then go back to the Engineer's Workbench and get details from the quote.
That's because our internal part number would not be created until the quote was accepted and we received an order. This made it a little easier the always have the link in the part master to the quote.
Greg
----- Original Message -----
Sent: Friday, February 20, 2009 2:05 PM
Subject: Re: [Vantage] Quote Module in version 6.1
I believe that, when you add check out the revision of the 'new' part in part Master, in Engineer's Workbench, you can 'get Details' form the Quote.
--- On Fri, 2/20/09, Jasper Recto <jrecto@...> wrote:
Subject: [Vantage] Quote Module in version 6.1
To: "Vantage Groups (vantage@yahoogroups.com)" <vantage@yahoogroups.com>
Date: Friday, February 20, 2009, 3:00 PM
If we quote a part that does not exist in our part master and use the Mfg Details option to build the routings and BOM, can we easily add that part to the part master?
What are our options? Do we have to manually create that part along with its BOM again?
Jasper Recto
Director of Information Technology
Loc Performance Products, Inc.
734.927.3835
The information transmitted is intended only for the person or entity to which it is addressed and may contain confidential and/or privileged material. Any review, retransmission, dissemination or other use of, or taking of any action in reliance upon, this information by persons or entities other than the intended recipient is prohibited. If you received this in error, please contact the sender and delete the material from any computer.
ITAR Disclaimer
Technical data obtained from Loc through any electronic solicitation are subject to U.S. Export Control Laws including the International Traffic in Arms Regulations. Such technical data may not be disclosed to foreign persons or otherwise exported without first obtaining required U. S. Government export authorization.
Jasper Recto
734.927.3835
ITAR Disclaimer
Jasper Recto
734.927.3835
ITAR Disclaimer
