Quote Form Totals
Cathy,
That's what I've done but it still doesn't subtotal the misc. charges, it only uses one of the charges for some reason.
--- In vantage@yahoogroups.com, "Cathy" <cathy@...> wrote:
> You will need to do a subtotal on the misc charges in the sub-report and
> make this a shared variable.
> This is what we used in the subreport
> Shared NumberVar TSQuoteMiscCharges;
> TSQuoteMiscCharges := Sum ({QuoteLnMsc.MiscAmt})
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> Sean Toler
> Sent: Friday, February 15, 2013 10:32 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Quote Form Totals
> Thanks. I gave that a try and was able to get some success, however, if
> there are multiple lines with multiple misc. charges, the misc. charges are
> not being summarized. It is only using one of the misc. charges in the final
> calculation.
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "CalvinDekker" wrote:
> > Sean -
> > You may want to check out this instructional message:
> http://forums.codeguru.com/showthread.php?449494-How-to-get-formula-field-va
> lue-from-Subreport-to-main-report
> > Then use another formula field to add up the values returned from the
> sub-report(s). This must be placed in a report section that is displayed
> after the sub-report section(s)
> > Hope this helps,
> > Calvin Dekker
> > Office: 630-672-7688 Ext. 1484
> > Email: calvin@
> > http://www.codabears.com
> > "No trees were harmed during the sending of this message, however a large
> number of electrons were terribly inconvenienced."
> > --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Sean
> Toler" wrote:
> > > Hello,
> > > I have been asked to add a line at the bottom of our quote form that
> gives a grand total. At first I thought this would be easily done with a
> summary of the @extendedprice formula until I noticed the Line Misc Charges
> subreport. I have very limited experience with shared variables and have
> been attempting to create one that would allow me to add the total misc
> charges to the total extended price but can not get it to work.
> > > Can someone walk me through this?
> > > Thanks!
Hello,
I have been asked to add a line at the bottom of our quote form that gives a grand total. At first I thought this would be easily done with a summary of the @extendedprice formula until I noticed the Line Misc Charges subreport. I have very limited experience with shared variables and have been attempting to create one that would allow me to add the total misc charges to the total extended price but can not get it to work.
Thanks!
You can still create your own, the Misc Tables are available to you outside
the sub report simply add together the misc charges , and add together the
lines, then add both of those together.
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
On Fri, Feb 15, 2013 at 10:44 AM, Sean Toler <seantoler@...>wrote:
> Hello,
> Thanks!
OK, that worked great until I tested removing the misc. charges and everything on the form disappeared when I did a print preview.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Hello,
> > Thanks!
On your Final Sum do a Check For Null on your MiscTotal if its Null replace
with 0
Somethign like
YourLineTotla + If IsNull(yourMisctotal) then 0 else yourmisctotal
*Jose C Gomez*
*Software Engineer*
E: jose@...
> outside
> the
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > http://www.linkedin.com/in/josecgomez> http://www.facebook.com/josegomez
> > http://www.google.com/profiles/jose.gomez> http://www.twitter.com/joc85>
> > On Fri, Feb 15, 2013 at 10:44 AM, Sean Toler wrote:
> > > Hello,
> gives
> summary
> have
> > > Thanks!
OK,
I got that idea too, so I created this formula:
If isnull(Sum ({@LineMiscAmount})) then (Sum ({@Extended Price}))
else
(Sum ({@LineMiscAmount})) + (Sum ({@Extended Price}))
But the same thing happens. Where would I substitute in your formula?
> with 0
> Somethign like
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > outside
> > the
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@
> > > > Hello,
> > gives
> > summary
> > have
> > > > Thanks!
Sean –
http://forums.codeguru.com/showthread.php?449494-How-to-get-formula-field-value-from-Subreport-to-main-report
Then use another formula field to add up the values returned from the sub-report(s). This must be placed in a report section that is displayed after the sub-report section(s)
Hope this helps,
Calvin Dekker
Email: calvin@...
"No trees were harmed during the sending of this message, however a large number of electrons were terribly inconvenienced."
--- In vantage@yahoogroups.com, "Sean Toler" <seantoler@...> wrote:
> Hello,
> Thanks!
Thanks. I gave that a try and was able to get some success, however, if there are multiple lines with multiple misc. charges, the misc. charges are not being summarized. It is only using one of the misc. charges in the final calculation.
--- In vantage@yahoogroups.com, "CalvinDekker" <calvind@...> wrote:
> Sean –
> Hope this helps,
> Calvin Dekker
> Email: calvin@...
> --- In vantage@yahoogroups.com, "Sean Toler" <seantoler@> wrote:
> > Hello,
> > Thanks!
Sean Toler
calculation.
> Sean -
> Hope this helps,
> Calvin Dekker
> Email: calvin@...
Toler" wrote:
> > Hello,
> > Thanks!
When you can add a miscellaneous charge for 0 $.
I don't think you need to check for nulls.
Jose Gomez
Sent: Friday, February 15, 2013 9:13 AM
To: Vantage
Subject: Re: [Vantage] Re: Quote Form Totals
with 0
Somethign like
*Jose C Gomez*
*Software Engineer*
E: jose@...
> outside
> > together
> the
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> > > Hello,
> > > that
> gives
> summary
> > > variables and
> have
> > > Thanks!
