QuickShip Rate Shopping setup
Has anyone successfully set up rate shopping with Kinetic and QuickShip 5.4? Do you have documentation that you would be willing to share?
Did you get anywhere with this?
Is this using freightquote.com engine or user loaded tables or navisphere?
I started down the path and discovered that I did not own the license, so I stopped.
You have to enable the ship methods in QS for rating and give them the min and max weights to rate.
I do not know where the rates come from.
We got it working in their sandbox, but I had other issues to work out, so we put it on the back burner for a little while. I need to get back to this asap. I may have some answers for you - what do you need to know?
