There isn’t a category for QuickShip so putting this here.
In case anyone else runs into this. There is a bug in the QuickShip 2022.2.9.0131 installer that removes a line from the web.config that’s required. Around line 703 need to put back the serviceHostingEnvironment collection. The EpicorFreightService.svc won’t compile without it and you’ll get an error.
@utaylor - there is also another pretty big bug that they were supposed to fix in 2022.2.9. In all previous version of QS going back 3+ years to versions 4 and 5. The document manager doesn’t save setting to the dB for country selections correctly. It just ignores the settings. I put a ticket in back in 2019 for it and again a couple months ago. Epicor still hadn’t fixed it but the ticket from January they finally moved it to dev and fixed it.
In QS they have a Document Manager where you setup the QS reports.
Some reports are only need for some foreign countries. But, the UI shows them as blanks after saving and in the database they write blank values. Instead of the actual country values.
