Quick way to identify which modules are turned on vs. turned off
Is there a way, using the cloud version of Epicor to see all modules and which are active (licensed) or not active? Came from an on prem shop and easiest way was to look at license file. Not sure if I can get to the license file or not (doubt it).
For now, I just bug our CAM with questions, or finance for what we are paying for. Bugging finance doesn’t answer the question of what we are not taking advantage of.
You should be able to see what’s available for the currently installed license. It may or may not match what you REALLY have but it’s a start.
Perfect. Other good information there as well.
Many Thanks,
Steve
You can check it on Epicweb also, which tells you what you are paying for.
