Quick Search through right click / Prompt Issue
Hello
In response to to some of the replies:
Yes my context key is an exact match for my BAQ return column.
Also none of mine where filter on null, so that is not the issue. its very hit and miss when this happens. I have launched Epicor tried the right click function and none where available, then went in and made changes or created new quick searches, then it would be available. So changes in the quick search maintenance seems to trigger something that brings them back.
--- In vantage@yahoogroups.com, "b_ordway" <cooner_55421@...> wrote:
> >> right click in the serial number search field
> >>and my quick searches do not appear sometimes and do other times.
> Just wondering if your underlying BAQs contain all the same key fields as the form where you are trying to add the right-click?
> --- In vantage@yahoogroups.com, "jarradlayne" <jarradlayne@> wrote:
> > Thanks for the responses I'll look into these suggestions.
> > --- In vantage@yahoogroups.com, "Sean McDaniel" <smcdaniel@> wrote:
> > > You might need to clear the client cache (in the folder, not from the application).
> > > ________________________________
> > > From: vantage@yahoogroups.com on behalf of jarradlayne
> > > Sent: Mon 2/18/2013 11:19 AM
> > > To: vantage@yahoogroups.com
> > > Subject: [Vantage] Quick Search through right click
> > > Hello group,
> > > I was wondering if anyone has run into the issue of when trying to access quick searches through the right click functionality of them not appearing. I've created several quick searches for lets say Serial Numbers. When I launch Epicor, open the Serial Number Track screen and right click in the serial number search field and my quick searches do not appear sometimes and do other times. Is this a bug in Epicor or am I missing something. All have the Shared and All Occurrences check boxes checked. They are always available when I select the search function from the button next to the field that launches the search window and navigate to the Quick Search tab.
> > > This is on 9.05.700c
> > > Thanks
Hello group,
Hello group,
Put a check in the Context Default to show in the "open with"
Of Sean McDaniel
Sent: Monday, February 18, 2013 8:37 AM
To: vantage@yahoogroups.com; vantage@yahoogroups.com
Subject: RE: [Vantage] Quick Search through right click
application).
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> on
Hello group,
When you're entering the context menu, you need to make sure that the "Customization Mode" checkbox in the upper right of the form is checked.
From: vantage@yahoogroups.com on behalf of Cliff Drumeller
Sent: Mon 2/18/2013 12:07 PM
From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On Behalf
Of Sean McDaniel
To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ; vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
application).
Hello group,
> Hello group,
> Thanks
I've seen this a well, still haven't found a cause or solution, but haven't really had a chance to address it yet
Sent from my Verizon Wireless 4G LTE DROID
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "Sean McDaniel" wrote:
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> on behalf of jarradlayne
> Hello group,
> Thanks
Good Day:
In some previous versions, the Quick-Search would not
run correctly if used right-click, but ran OK if used the "Quick-Search'
tab under normal search.
I have not checked it out in 9.05.700C
Len
Of jarradlayne
Sent: Tuesday, February 19, 2013 9:18 AM
Subject: [Vantage] Re: Quick Search through right click
application).
> Hello group,
> Thanks
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
> > Hello group,
> > Thanks
I had the same issue on Quick Searches for Part Numbers. I had 6 quick searches, two of them displayed with right click and the others did not. I noticed in Quick Search entry the two that did display had the "filter on null" checked on the criteria tab, the other 4 did not. When I checked filter on null for the other 4 and went back into part number and right clicked they all displayed. I dont understand it but it worked
Sent: Monday, February 18, 2013 2:02 PM
Â
From: mailto:vantage%40yahoogroups.com on behalf of Cliff Drumeller
To: mailto:vantage%40yahoogroups.com
From: mailto:vantage%40yahoogroups.com [mailto:mailto:vantage%40yahoogroups.com ] On Behalf
Of Sean McDaniel
To: mailto:vantage%40yahoogroups.com ; mailto:vantage%40yahoogroups.com
application).
Hello group,
