Thanks Kevin. I was able to figure it out earlier. It was rather
simple. The customization wasn't deployed on all available locations
for that menu. Once that was done the problem was solved.
Blake Clemens
IT Systems Engineer
Delmarva Millwork Corporation
(800) 360-2364 x132
Of Kevin Simon
Sent: Thursday, March 24, 2011 2:45 PM
Subject: RE: [Vantage] Quick Search Menu
Blake,
Go through that process in development mode. It will tell you what
process
is being called. Then, you'll need to use Process Calling Maintenance
and
SubProcess Maintenance to add these. I don't have all the steps to do
so,
but I'm sure if you search the group, you'll find it. Or, tech support
has
an answer book on it.
HTH,
Kevin Simon
SimsTrak Consulting
Behalf Of
Blake Clemens
Sent: Thursday, March 24, 2011 10:14 AM
I'm sorry, I should have been more clearer... example: open part
maintenance, enter a valid part number. Then right click on the part
number and in the Open With... option, that is where I need my newly
customized menu to appear. Sorry for the confusion.
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Blake Clemens
Sent: Thursday, March 24, 2011 10:06 AM
Subject: [Vantage] Quick Search Menu
How do I add a menu item to the Quick Search menu? We have a customized
Purchase Advisor menu that isn't showing up in the Quick Search. If you
right click a part and select Purchase Advisor the base form appears,
not the customized form. How do I modify this?
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Of Kevin Simon
Blake,
process
and
so,
has
HTH,
Kevin Simon
SimsTrak Consulting
Behalf Of
Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
Behalf
Of Blake Clemens
Blake Clemens
IT Systems Engineer
(800) 360-2364 x132
