I have created a quick search in our Customer menu. I am trying to add the same quick search as an option in our AR Aged Receivables Filter selection. It is not available, and I cannot find how to add it to the aged receivables filter. Has anyone done this before? Trying to let our users select customers by different currencies! thank you
Dan,
Quick searches are generally driven by a field like part number or invoice number as the result of the search.
You may need to recreate the quick search from a different resulting field. Like order number versus invoice number.
Is your quick search derived from a BAQ that you created? You can go into the BAQ and add Like fields at the far right tab of the BAQ. Then you can use the BAQ tab of the search dialogue box to see/use the BAQ.
Brad
Thank you! That’s perfect, I will use the BAQ search instead! thank you
