Hello everyone!!! I have a very weird issue with quick search in 10.0.700.
there is already a quick search on project entry module, if I run a test in BAQ maintenance I can tell query is working properly.
the quick search criteria is already generated but if I try to edit criterias or adding a new one i get the following error:
Server Side Exception
The table/field is not valid.
Error Detail
Description: The table/field is not valid.
Program: Ice.Services.BO.QuickSearch.dll
Method: QuickSearchCriteriaBeforeUpdate
Server Trace Stack: at Ice.Services.BO.QuickSearchSvc.QuickSearchCriteriaBeforeUpdate()
at Ice.Services.Trace.TablesetProfilingCollector.DoRowEventTrace(String tableName, String methodName, Int32 rowCount, Action action)
at Ice.TablesetBound`3.CreateRow(IceDataContext dc, Int32 tableNum, IIceTable tbl, IceRow newTablesetRow, TablesetProfilingCollector parentTraceCollector)
at Ice.TablesetBound`3.WriteTable(IceDataContext context, Int32 tableIndex, IIceTable table, TablesetProfilingCollector parentTraceCollector)
at Ice.TablesetBound`3.InnerUpdate(IceDataContext context, TFullTableset tableset)
at Ice.Services.BO.QuickSearchSvc.Update(QuickSearchTableset& ds)
at Ice.Services.BO.QuickSearchSvcFacade.Update(QuickSearchTableset& ds)
at SyncInvokeUpdate(Object , Object[] , Object[] )
at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
at Epicor.Hosting.OperationBoundInvoker.Invoke(Object instance, Func`2 func)
at Epicor.Hosting.Wcf.EpiOperationInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs)
at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage11(MessageRpc& rpc)
at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(RequestContext request, Boolean cleanThread, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(RequestContext request, OperationContext currentOperationContext)
at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(IAsyncResult result)
at System.ServiceModel.Dispatcher.ChannelHandler.OnAsyncReceiveComplete(IAsyncResult result)
at System.Runtime.Fx.AsyncThunk.UnhandledExceptionFrame(IAsyncResult result)
at System.Runtime.AsyncResult.Complete(Boolean completedSynchronously)
at System.ServiceModel.Channels.SecurityChannelListener`1.ReceiveItemAndVerifySecurityAsyncResult`2.InnerTryReceiveCompletedCallback(IAsyncResult result)
at System.ServiceModel.Channels.TransportDuplexSessionChannel.TryReceiveAsyncResult.OnReceive(IAsyncResult result)
at System.ServiceModel.Channels.SynchronizedMessageSource.ReceiveAsyncResult.OnReceiveComplete(Object state)
at System.ServiceModel.Channels.SessionConnectionReader.OnAsyncReadComplete(Object state)
at System.Net.LazyAsyncResult.Complete(IntPtr userToken)
at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken)
at System.Net.Security.NegotiateStream.ProcessFrameBody(Int32 readBytes, Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security.NegotiateStream.ReadCallback(AsyncProtocolRequest asyncRequest)
at System.Net.AsyncProtocolRequest.CompleteRequest(Int32 result)
at System.Net.FixedSizeReader.CheckCompletionBeforeNextRead(Int32 bytes)
at System.Net.FixedSizeReader.ReadCallback(IAsyncResult transportResult)
at System.ServiceModel.Channels.ConnectionStream.IOAsyncResult.OnAsyncIOComplete(Object state)
at System.Net.Sockets.SocketAsyncEventArgs.OnCompleted(SocketAsyncEventArgs e)
at System.Net.Sockets.SocketAsyncEventArgs.FinishOperationSuccess(SocketError socketError, Int32 bytesTransferred, SocketFlags flags)
at System.Net.Sockets.SocketAsyncEventArgs.CompletionPortCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* nativeOverlapped)
at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32 errorCode, UInt32 numBytes, NativeOverlapped* pOVERLAP)
Client Stack Trace
at Epicor.ServiceModel.Channels.ImplBase`1.ShouldRethrowNonRetryableException(Exception ex, DataSet[] dataSets)
at Ice.Proxy.BO.QuickSearchImpl.Update(QuickSearchDataSet ds)
at Ice.Adapters.QuickSearchAdapter.OnUpdate()
at Ice.Lib.Framework.EpiBaseAdapter.Update()
at Ice.UI.App.QuickSearchEntry.QuickSearchTransaction.adapterUpdate()
at Ice.Lib.Framework.EpiMultiViewTransaction.Update(IEnumerable`1 dataSets)```
![image|389x180](upload://fqjnSWyfKTppL2l03EOQfH86CY1.png)
![image|690x256](upload://mAhRAX5i5Sg7ohm2KffFKFaK8Fs.png)
i decided to create a brand new BAQ, create a brand new quick search, everything runs great until I decide to include in the criteria fields like: Project.Number01, Project.Character01, Project.ShortChar01, etc, etc, etc....
have you ever seen something like this before?? Do you have any ideas or suggestions??
Best Regards..
