Quick Job Entry
Has anyone attempted this
1)     Prompt for the same information as the Quick job create screen, but in a tabular, multiple create layout screen. Allow the user to enter up to 8 lines of info 8 job numbers, 8 part numbers, 8 quantities
Â
2)     Have a button to Cancel and a button to Execute
3)Â Â Â Â Â When the user presses Execute then:
a.      Call the create job process, be it the fast screen or another.
b.     Save the job.
4)Â Â Â Â Â All data for the create job process should be passed from the screen.
5)Â Â Â Â Â The end result should be 8 jobs created with the 8 job numbers I have entered and the 8 part numbers, and the quantity.
Sent from my Verizon Wireless BlackBerry
Has anyone ever customized Quick Job Entry?
What I am looking to add is two custom fields on Quick Job Entry that
will link to the ProjectID and CommentText. None of these fields are
initially available so I created a FKV to the Jobhead. Now the table and
fields are available, but when I add them they are set as read only and
I can't change that.
I want to the user to enter information into these 2 fields, which are
currently set to Character01 and 02. Then I'll use a BPM to populate
that information to he Jobhead for the Project and Comment. Any ideas
why I can't get these to work? What could I be missing?
Travis Late
ERP Project Manager
M-B Companies, Inc
1200 Park Street
Chilton, WI 53014
Phone: 920-898-1560 Ext.152
Cell: 920-960-0062
Email: tlate@... <mailto:tlate@...>
M-B Companies Confidentiality Notice:
This message is being sent by M-B Companies. It is intended exclusively for
the individuals and entities to which it is addressed. This communication,
including any attachments, may contain information that is proprietary,
privileged and confidential if you are not the named addressee; you are not
authorized to read,print,retain copy or disseminate this message or any part
of it.If you have received this message in error, please notify the sender
immediately by email.
