Questions regarding RMAs and Repairs
I set up a couple of labor item numbers (LINSPECT=Labor to inspect and advise, LREPAIR=Labor to repair/update & LSERVICE=Service Call) and use those as the items for our service work. We charge a nominal amount to do a Inspect & Advise to give a quote
(which is not charged if warranty is determined). We use the Repair as line 2 of the order (unless we go right to repair - usually because of customer upsetness) and charge any materials, items or subcontract costs tot his line. Service Call is just that,
when we send a person on-site, we use this line to collect costs and occasional fees.
Hope this is of some help to you...
Rick Gors
MR/MMIS
Osco
Mike Lowe wrote:
> We have a division that has a standard product line. We are currently in the
> process of implementing Vantage and wanted to see how others were using RMA's to
> process Repair Orders.
> For example, customer sends back an amplifier. Do you use the same part number
> as was sent to the customer? Or do you create a new part number to reflect that
> this will be a repair? I'm concerned about some costing issues if we use the
> same part number. Also, we will rarely be able to tie back to the original
> sales order as the product is sold to distributors and then to end users.
> However, the end user will be sending the product back to us. If the part is
> under warranty, we cover the costs. If the part is not under warranty we will
> prepare and estimate and forward to the customer for their approval before we
> perform the repair.
> Also, I'm having a hard time understanding the RMA flow since the RMA queues
> have been removed (one change from 3.0 to 4.0). I would be curious to hear how
> other users are managing the flow of information.
> Thanks,
> Mike Lowe
> Connor Manufacturing Services
> MLowe@...
> To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please go to: http://groups.yahoo.com/group/vantage/files/. Note: You must have already linked your email address to a yahoo id to enable access.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
perform the repair.
Mike Lowe
MLowe@...
