We don’t currently own the advanced production module. I’ve been trying to look through the help to see if it can do what we need. We have two situations I would like to use it for:
First case, parts burned on a plasma table. Lets say we have 5 orders that use the same raw material, and I will nest together:
Part A: Qty 4
Part B: Qty: 2
Part C: Qty: 3
Part D: Qty: 2
Part E: Qty: 4
Lets say the nests turn out as such:
Nest 1:
(4) Part A
(2) Part B
(1) Part C
Nest 2:
(2) Part C
(2) Part D
(4) Part E
You can see Part C has be split across two different nests (batches). Is this possible to do with batching, or do you have to batch the entire jobs? What happens if the 1 piece of part C come out bad?
The second situation I was wondering about is if jobs can be batched multiple times. For example, a bunch of parts that are all burned on the plasma table, then all get different intermediary operations, but all finish with a painting operation. Can make a batch job for the plasma and the painting, while leaving the original jobs with the intermediary operations?
How is scrap handled? Like if you produce __ lbs of scrap setting up a machine to do a batch job, how is the cost distributed over the parent jobs?
Hopefully some of you folks that have experience with batch jobs can chime in.
You have to batch the entire job. You would need to split the job for part c first and batch each job separately.
You batch by first selecting a specific operation, and then you either batch all the way to the end of the BOO, or all the way to the beginning of the BOO, from the operation you select, you can’t skip or pick/choose what ops get batched and what don’t.
