Joe, look at your App Servers and see what your max server settings are. You may not need as many servers. Also, make sure your other dabases are not running (Pilot, Test, Train) if you are not using them and turn off the app servers for those as well. If you want to save memory you can set your databases to read only mode. If you need the tuning guide I can send it to you
--- On Fri, 2/13/09, Rojas, Joe <joe.rojas@...> wrote:
Subject: [Vantage] Questions about _proapsv and _sqlsvr processes
Date: Friday, February 13, 2009, 3:40 PM
Hi All,
I find that I have to regularly log into our Vantage server to see how
much free RAM is available to the system.
Typically, I check because someone tells me that the server is running
slow.
The server as 4GB of RAM and sometimes when I check there is only 256MB
free! I look at the processes running and there are a bunch of
_proapsv.exe processes running that are not doing anything (0 CPU usage)
but have 500MB or more of RAM usage.
If I kill these processes, I get RAM back, my paging file usage drops
and everything is running fine again...until the next time.
Am I missing something here? Is something not configured correctly? Or
is this just how Progress/Vantage works and should be part of my weekly
server maintenance? (Hoping not!)
I also fine _sqlsrv.exe processes that I know are there because of ODBC
connections but they never close. Should they?
Joe
