Set-up your Purchase order with three lines - The first line being for
the total amount of the PO.
The other two lines put a qty of say (1) but, no price. When the first
Invoice comes in put the amount of the invoice on the second line of the
PO lower the first line by that amount and then you can *receive *in
line 2 of your PO. The next invoice is received do the same thing - put
that invoice amount on line 3 and lower line 1 on your PO and then
receive in line 3 of your PO. The final invoice comes in and you then
can receive line one of you PO. There will not be a purchase variance -
I used your example below.
Peggy Szymanski
Apex Piping Systems, Inc.
Peggy Szymanski
vanebewe wrote:
> Hi,[Non-text portions of this message have been removed]
> We issue a PO for the costs associated with prepping a site
> installation. For one particular vendor, we issue a PO for the full
> cost and then when we are invoiced, we have our purchase
> dpt "receive" in the line item into Epicor so that we can properly
> match the receipt to hte invoice. There is no actual physical
> receipt of the item.
> However, the vendor typically sends us multiple invoices that make
> up the total PO cost. So for example: we have one line item on the
> PO for $25,000 but will receive 3 different invoices for $5,000,
> $10,000 and 10,000. When Purchasing receives in the line item, then
> that line item is no longer available for the other two invoices.
> Is there a certain way to handle this scenario? Typically, the
> original PO cost ends up being invoiced at that full cost, but just
> via multiple invoices. So we don't want any purchase price variances
> booked.
> Any suggestions would be great,
> Thanks in advance,
> -Vanessa
> __________ NOD32 2166 (20070403) Information __________
> This message was checked by NOD32 antivirus system.
> http://www.eset.com
