Question - How to use a BAQ to identify records with blank field
Thank you everyone for your help! I was forgetting the outerjoin when I created the BAQ before.
It works great now.
Once again, thanks for everyones help.
Jason
We are in the process of creating a new database with clean information as we are now one company where as we were several operating together in the past.
We have reports created in Crystal which are run every morning for different purposes - To identify Parts with out MOMS , Parts without Customer Part Numbers etc.
These are currently run through ODBC and we are working to convert them to BAQS to attach them to an overnight schedule.
Does anyone know of a way to filter a BAQ looking for blank fields?
Example - All parts that do not have a corresponding Customer Part Number in our CustXPart Table
Any help would be greatly appreciated. :-)
Hi LakeIT,
You could use the criteria to filter out those fields with blank fields. Hope it can help you
Best Regards
Adrian
Really? How do you do it? I tried and couldn't come up with a query.
You can't leave the criteria field blank, you can't use '' and you can't use ?.
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix / Picometrix
    bspolarich@... ~ 734-864-5618 ~ www.advancedphotonix.com
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of adriancctfssb
Sent: Thursday, March 18, 2010 3:44 AM
Subject: [Vantage] Re: Question - How to use a BAQ to identify records with blank fields
Hi LakeIT,
Best Regards
Adrian
On trick is to compare it to another field that you know will always be blank.
Sent: Thu, March 18, 2010 9:19:33 AM
Subject: RE: [Vantage] Re: Question - How to use a BAQ to identify records with blank fields
Â
-bws
    bspolarich@advanced photonix. com ~ 734-864-5618 ~ www.advancedphotoni x.com
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of adriancctfssb
To: vantage@yahoogroups .com
Hi LakeIT,
Best Regards
Adrian
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups. yahoo.com/ group/vantage/ files/.
(2) To search through old msg's goto: http://groups. yahoo.com/ group/vantage/ messages
(3) To view links to Vendors that provide Vantage services goto: http://groups. yahoo.com/ group/vantage/ linksYahoo! Groups Links
I tried comparing it to character10 in the same table which I know is blank and then I didnt get anything.
It should just be
FieldName(XPartNum) = (IsConst not checked) ToDataTableID(CustXPart)ToFieldName(Character10)
Correct?
> From: Brian W. Spolarich <bspolarich@...>
> ÂÂ
> -bws
> Hi LakeIT,
> Best Regards
> Adrian
When I used Part.Character10, it worked. Try that. It might be getting confused by comparing fields from the same table. I also used CustXPart.PartNum to compare it to, but it should work no matter what field you use in the CustXPart table. Just remember to check the outer join in Phrase Builder/ Table Relations.
> It should just be
> Correct?
> > From: Brian W. Spolarich <bspolarich@>
> > ÂÂ
> > -bws
> > Hi LakeIT,
> > Best Regards
> > Adrian
