Query Sort Order Issues
I have a query which is returning cross company customer information. I have the query set up to be sorted first by Company and then by CustID. However, when I run this query whether from BAQ designer or from the dashboard which uses it, the output of the query is sorted by Company and then by CustNum. If I remove my sort order the output is still sorted in the same way. Maybe I am missing something obvious, but I am very stumped as to why the query would sort in a way contrary to the sort order that I have set up. Any thoughts?
Hello Fireball,
Make sure your sort order is on the Top Level Query and not on a Inner Sub-Query (by mistake).
LOL Haso, that was going to be my suggestion as I’ve fallen victim to it myself plenty of times.
The second is make sure you don’t have a OrderBy override such as OPTION RECOMPILE inside your Execution Settings.
You can check by going to Actions → Execution Settings
If you need both, you will need to use an Advanced Group By Clause.
It said Haso was in a meeting so I came here instead but he just wanted to get a green solution checkmark added to his tally he was just pretending to be busy.
If I answer on MS Teams I don’t get my solutions count up. I prefer Forums, perhaps one day I will beat @josecgomez :smiley:
https://www.epiusers.help/u?order=solutions&period=all
I’m still gunning for most genuine likes (hearts) given. Still lagging Mark.
Here’s one you can like.
Only because I’ve been on here longer, I imagine. Over the last year, NOBODY is as appreciative as you. And you have the award to prove it!
Thank you for the support John :pray:
It’s hanging proudly in my cubicle right now!
I wish I could say the same…
