I spent too long yesterday adding a QR code to an SSRS report and found too many conflicting instructions. So here’s a brief video on adding a QR code to an SSRS report via a .dll. You can also use web services to generate the image, but I went with the .dll method so I could encode complicated data that couldn’t be easily passed in a url string.
When you enable SSRS for an App, via EAC, the deployment adds a few DLL’s to the ...\ReportServer\bin\ folder, and updates the rssrvpolicy.config file with some entries about DLL’s the Epicor adds.
Here’s a sample of what is added to the rssrvpollicy.config file.
<CodeGroup
class="UnionCodeGroup"
version="1"
PermissionSetName="FullTrust"
Name="EpicorCodeGroup"
Description="Epicor Code group for data processing extension">
<IMembershipCondition
version="1"
class="UrlMembershipCondition"
Url="\\usdcadbs00375\C$\Program_Files\Microsoft_SQL_Server\MSRS13.MSSQLSERVER\Reporting_Services\ReportServer\bin\CLSEpicor.dll"_
</CodeGroup>
a similar entry exists in rssrvpolicy.config, for EpiNum2Words.dll
Why doesn’t adding the QR DLL to the bin folder, require an entry in the rssrvpolicy.config file?
That’s a good question. I’ve found google results that say you also have to add it to the GAC. I’ve used the method in my video on 3 different servers and it worked on all of them. I forgot to mention you need to put it in your visual studio directory on your local machine to run report builder locally.
This was extremely useful and works really well in an on-prem environment. We are looking at going to the cloud with Epicor but are still going to need to generate QR codes for our labels. Do you have any suggestions? I’m guessing that Epicor isn’t going to allow the QRCode.dll to be placed on their reporting server. Any suggestions would be appreciated.
It is working but I have to say the solution makes me itchy for various reasons, mostly relating to the dubious reliability.
I imagine there aren’t any recent developments regarding Epicor implementing their own solution. I met with a support rep yesterday and the solution he gave me was the ‘use the kaywa url method’ @TobyLai posted here earlier.
Is anyone aware of a more reliable 3rd party? I would feel much better about this solution if I had some guarantees it would always work.
I have used the ID Automation solution for a number of Epicor Customers and it works well, is provided by a reputable company that offers support, AND it is basically a one time purchase.
Our company has a server that host our own API. QR Code generator can be called from a web link and SSRS and crystal report both can call that API. Having your own service is better option as you have full control on it.
So much this. Relying on a third party internet QR generator adds an uncontrolled input to SSRS. While that’s not an easy exploit by any means… There have been related SSRS patches in the past, and a QR generator exploiter should know that they’re delivering to far higher than average amount of SSRS. Especially for SaaS clients - risk exposure may affect other clients on shared resources.
If you read the article carefully, this line should jump out at you:
“By the end of 2027, retailers would need to ensure their POS systems are equipped with scanners capable of reading both traditional barcodes and 2D barcodes.” [emphasis mine]
The Code 39 stuff on tags and travelers and what-all-else-have-you isn’t just going to evaporate in 2027. Yes, those and other 1D barcodes will eventually go away, but I would certainly not consider it a priority at the moment.
