You can use a SQL jobs to update a UD table and then the BAQ would use the UD table.. You could also make a view and then use an external BAQ.
Sent: Thursday, May 05, 2016 11:25 AM
To: yahoogroups
Subject: [Vantage] Purchasing Forecast Dashboard E9.05
I recently built a dashboard for Purchased material's to be able to see the demand and supply 13 months out. The tool is intended to be used to inform our Suppliers of what they should expect to see in those months. I used the PartDtl table for the information and everything seemed to be working the way that Purchasing wanted it to. Just recently some purchased parts were setup on a 'Tag System', so the trigger to reorder is the tag. Since the tag is the trigger to order the Process MRP and Generate PO Suggestions was turned off, so I have no suggestions generating. I was asked if there was a way to still be able to see what is coming for these parts. I don't know of any easy way to be able to do this. Does anyone have any suggestions?
Melissa
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6240 and immediately delete the communication.
IF Reqty does not eq Issued qty.
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Thursday, May 5, 2016 8:25 AM
To: yahoogroups <vantage@yahoogroups.com>
Melissa
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
