Received the following error while one of our users was printing a PO.
Program Ice.Services.Lib.RunTask raised an unexpected exception with the following message: RunTask: Client found response content type of ‘text/html; charset=utf-8’, but expected ‘text/xml’.
The request failed with the error message:
Now we can not get any PO’s to print. Seems all other forms are printing without issue just the PO’s that won’t print.
No changes have been made to any PO forms.
Tried printing with the base PO form
Client cache cleared
Task Agent Restarted
Full Error message from server logs
Source: EpicorTaskAgent3.2.200.0
Date: 7/8/2022 2:24:44 PM
Event ID: 0
Task Category: None
Level: Warning
Keywords: Classic
User: N/A
Computer: XX.XXXX.local
Description:
SLC-PROD: An error occurred trying to run task ID 311124 for agent SystemAgent on the application server (User: XXXXXX, Task Description: Purchase Order).
Error Detail:
Program Ice.Services.Lib.RunTask raised an unexpected exception with the following message: RunTask: Client found response content type of 'text/html; charset=utf-8', but expected 'text/xml'.
<html>
<head>
<title>Thread was being aborted.</title>
<style>
body {font-family:"Verdana";font-weight:normal;font-size: .7em;color:black;}
p {font-family:"Verdana";font-weight:normal;color:black;margin-top: -5px}
b {font-family:"Verdana";font-weight:bold;color:black;margin-top: -5px}
H1 { font-family:"Verdana";font-weight:normal;font-size:18pt;color:red }
H2 { font-family:"Verdana";font-weight:normal;font-size:14pt;color:maroon }
pre {font-family:"Lucida Console";font-size: .9em}
.marker {font-weight: bold; color: black;text-decoration: none;}
.version {color: gray;}
.error {margin-bottom: 10px;}
.expandable { text-decoration:underline; font-weight:bold; color:navy; cursor:hand; }
</style>
</head>
<body bgcolor="white">
<span><H1>Server Error in '/ReportServer_XXXXXXX' Application.<hr width=100% size=1 color=silver></H1>
<h2> <i>Thread was being aborted.</i> </h2></span>
<font face="Arial, Helvetica, Geneva, SunSans-Regular, sans-serif ">
<b> Description: </b>An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
<br><br>
<b> Exception Details: </b>System.Threading.ThreadAbortException: Thread was being aborted.<br><br>
<b>Source Error:</b> <br><br>
<table width=100% bgcolor="#ffffcc">
<tr>
<td>
<code>
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.</code>
</td>
</tr>
</table>
<br>
<b>Stack Trace:</b> <br><br>
<tr>
<td>
<code><pre>
[ThreadAbortException: Thread was being aborted.]
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +312
System.Web.ApplicationStepManager.ResumeSteps(Exception error) +762
System.Web.HttpApplication.System.Web.IHttpAsyncHandler.BeginProcessRequest(HttpContext context, AsyncCallback cb, Object extraData) +256
System.Web.HttpRuntime.ProcessRequestInternal(HttpWorkerRequest wr) +444
</pre></code>
</td>
</tr>
</table>
<br>
<b>Version Information:</b> Microsoft .NET Framework Version:2.0.50727.8762; ASP.NET Version:2.0.50727.8762
</font>
</body>
</html>
[ThreadAbortException]: Thread was being aborted.
at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
at System.Web.HttpApplication.ApplicationStepManager.ResumeSteps(Exception error)
at System.Web.HttpApplication.System.Web.IHttpAsyncHandler.BeginProcessRequest(HttpContext context, AsyncCallback cb, Object extraData)
at System.Web.HttpRuntime.ProcessRequestInternal(HttpWorkerRequest wr)
Stack Trace:
at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
at Ice.Core.SsrsReportService.ReportExecutionService.Render(String Format, String DeviceInfo, String& Extension, String& MimeType, String& Encoding, Warning[]& Warnings, String[]& StreamIds) in C:\_Releases\ICE\ICE3.2.200.7\Source\Server\Internal\Lib\TaskLib\Web References\SsrsReportService\Reference.cs:line 633
at Ice.Core.SsrsReporting.SsrsRendererBase.Render(SsrsRenderInformationBase renderInformation) in C:\_Releases\ICE\ICE3.2.200.7\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 142
at Ice.Core.SsrsReporting.SsrsRendererBase.<>c__DisplayClass12_0.<TraceReportRendered>b__0() in C:\_Releases\ICE\ICE3.2.200.7\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 87
at Epicor.Hosting.Trace.TraceHandle.TimeAction(Action actionToTime) in C:\_Releases\ICE\ICE3.2.200.7\Source\Framework\Epicor.System\Hosting\Trace\TraceHandle.cs:line 92
at Epicor.Hosting.Trace.TraceHandle.AddTimedIfEnabled(String traceFlag, Action actionToTime, Func`2 messageBuilder) in C:\_Releases\ICE\ICE3.2.200.7\Source\Framework\Epicor.System\Hosting\Trace\TraceHandle.cs:line 39
at Ice.Core.SsrsReporting.SsrsRendererBase.TraceReportRendered(String printProgram, String ssrsRenderFormat, Func`1 timedAction) in C:\_Releases\ICE\ICE3.2.200.7\Source\Server\Internal\Lib\TaskLib\SsrsReporting\SsrsRendererBase.cs:line 95
at Ice.Core.SsrsReporting.ReportProcessorBase.RenderReportForPreviewOrGenerate(RenderedSsrsReport renderedReport) in C:\_Releases\ICE\ICE3.2.200.7\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 258
at Ice.Core.SsrsReporting.ReportProcessorBase.ProcessReportPart(String reportLocation) in C:\_Releases\ICE\ICE3.2.200.7\Source\Server\Internal\Lib\TaskLib\SsrsReporting\ReportProcessorBase.cs:line 152
at Ice.Core.SsrsReporting.StandardReportProcessor.ProcessReportParts() in C:\_Releases\ICE\ICE3.2.200.7\Source\Server\Internal\Lib\TaskLib\SsrsReporting\StandardReportProcessor.cs:line 31
at Ice.Core.RoutingAndBreaking.ReportPersister.Persist(ReportInstanceInformation reportInstance, Func`2 reportsRenderer, Action`1 fillSysRptLstRow, Action`2 processReport) in C:\_Releases\ICE\ICE3.2.200.7\Source\Server\Internal\Lib\TaskLib\RoutingAndBreaking\ReportPersister.cs:line 50
at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.RenderUnroutedSsrsReport() in C:\_Releases\ICE\ICE3.2.200.7\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 301
at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.RunSsrsReportIfEnabled() in C:\_Releases\ICE\ICE3.2.200.7\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 226
at Ice.Core.RptBase.ReportSsrsDatabaseBuilder.ProcessReportWithDataInPlace(Func`2 executeCommand, Func`2 executeReader, SqlObjectsCreated sqlObjectsCreated) in C:\_Releases\ICE\ICE3.2.200.7\Source\Server\Internal\Lib\TaskLib\RptBase\ReportSsrsDatabaseBuilder.cs:line 111
at Ice.Core.RptBase.ReportDatabaseBuilder.XMLClose() in C:\_Releases\ICE\ICE3.2.200.7\Source\Server\Internal\Lib\TaskLib\RptBase\ReportDatabaseBuilder.cs:line 93
at Erp.Internal.PM.POForm.RunProcess(Int64 instanceTaskNum, String outputFileName) in c:\_Releases\ERP\RL10.2.200.0\Source\Server\Internal\PM\POForm\POForm.cs:line 426
at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in C:\_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 98
at Ice.Hosting.TaskCaller.ExecuteTask() in C:\_Releases\ICE\RL3.2.200.0\Source\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 57
at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in C:\_Releases\ICE\RL3.2.200.0\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 63
at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in C:\_Releases\ICE\RL3.2.200.0\Source\Server\Services\Lib\RunTask\RunTask.cs:line 547
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="EpicorTaskAgent3.2.200.0" />
<EventID Qualifiers="0">0</EventID>
<Level>3</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2022-07-08T21:24:44.000000000Z" />
<EventRecordID>6292</EventRecordID>
<Channel>Epicor ICE Task Agent Service</Channel>
<Computer>XXXX.XXXXXX.local</Computer>
<Security />
</System>
<EventData>
<Data>SLC-PROD: An error occurred trying to run task ID 311124 for agent SystemAgent on the application server (User: XXXXXX, Task Description: Purchase Order).
Error Detail:
<html>
<head>
<style>
</style>
</head>
<span><H1>Server Error in '/ReportServer_XXXXXX' Application.<hr width=100% size=1 color=silver></H1>
<br><br>
<tr>
<td>
<code>
</td>
</tr>
</table>
<br>
<tr>
<td>
<code><pre>
</pre></code>
</td>
</tr>
</table>
<br>
</font>
</body>
</html>
Stack Trace:
at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in C:\_Releases\ICE\RL3.2.200.0\Source\Server\Services\Lib\RunTask\RunTask.cs:line 547</Data>
</EventData>
</Event>```
