We have had what sounds like the same problem. Called tech support and they
e-mailed a program that allowed you to delete the bad entries. Easy to use.
In our case, a purchasing agent was causing his own grief by switching
screens in the middle of creating his record, then forgetting what he had
started and starting over - he finally figured it out himself!
Hope that helps.
Marilyn Fairchild
Systems Administrator
Sent: Wednesday, August 21, 2002 10:54 AM
Subject: [Vantage] Purchase Order Entry glitch: Vantage 5.10.124
Purchase Order with Errors (91) (984)
Somehow (new person to Po's and Vantage) a Purchase Order was created and
the only information it contains is a number and a buyer. It does not
contain a Vendor or any other header information.
We cannot delete it. It does not show up in PO Tracker.
Is anyone is aware of a fix? Any foreseeable problems if we just live with
it?
The error messages are as follows (can only get there from PO entry search
button)
No POHeader record available (91)
Error Attempting to push run time parameters on the stack (984).
Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
Hope that helps.
Marilyn Fairchild
it?
button)
