Jose C Gomez
T: 904.469.1524 mobile
On Fri, Jan 23, 2015 at 3:42 PM, Manasa Reddy mreddy@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p>
I better clarify….we currently have data in these types of fields but the whole customization is in Job Entry.
We wanted to move this “sheet†over to Project Entry and modify the fields in Project instead of in the Job mostly because it is the project managers and engineering that update this information.
Manasa
Â
Sent: Friday, January 23, 2015 2:38 PM
Subject: RE: [Vantage] Project Entry Customization - 9.05.700CÂ
Â
Quick question, are the UD fields available to add to the new sheet? You know, JobHead.Number01, etc? As I was going through the video it did not look like they would be available….
Manasa
Â
Â
Â
Sent: Friday, January 23, 2015 2:30 PM
To: Vantage
Subject: Re: [Vantage] Project Entry Customization - 9.05.700CÂ
Â
Its tehre now just go to the little settings wheel and change the res to 720 in the video
Jose C GomezSoftware Engineer
T: 904.469.1524 mobileE: jose@...
http://www.josecgomez.com
Â
Â
Â
Â
Â
Â
Quis custodiet ipsos custodes?Â
On Fri, Jan 23, 2015 at 3:16 PM, Manasa Reddy mreddy@... [vantage] <vantage@yahoogroups.com> wrote:
Â
I shall! My old eyes can’t take it…
M
Â
Sent: Friday, January 23, 2015 1:53 PM
To: Vantage
Â
If you wait a little while it should show up in HD where you can actually read the stuff I am clicking / doing.
Â
Â
Â
Â
Â
Â
On Fri, Jan 23, 2015 at 2:43 PM, Manasa Reddy mreddy@... [vantage] <vantage@yahoogroups.com> wrote:
Â
Jose, it looks like it will work. Ill play around with it this weekend and let you know. I appreciate the help!
Manasa
Â
Sent: Friday, January 23, 2015 1:32 PM
To: Vantage
Â
That is  easily done with a FKV Foreign Key Data View here you go
Â
Â
It still processing so it may take a few minutes before you can see it.
Â
Â
Â
Â
Â
Â
On Fri, Jan 23, 2015 at 11:32 AM, Manasa Reddy mreddy@... [vantage] <vantage@yahoogroups.com> wrote:
Â
Exact version in Subject line!
In Project Entry (and then of course in Project tracker), when I click on the Jobs tab, I want an Engineering Status tab, so that if I have three jobs associated to the project (job # 123, 456, 789)Â when I pick one of these jobs, my Status page reflect information for that job.Â
I hope that makes sense. Otherwise we can always chat on this! I appreciate your help, Jose!
Manasa
Â
Â
Â
Sent: Friday, January 23, 2015 10:12 AM
To: Vantage
Â
Tell me exactly what you want and I'll try to throw something together for you. Are you in 9x?
Â
Â
Â
Â
Â
Â
On Fri, Jan 23, 2015 at 11:08 AM, Manasa Reddy mreddy@... [vantage] <vantage@yahoogroups.com> wrote:
Â
Is it A LOT of trickery, or just a little trickery which you would be willing to share?!?! You know I’m cheap…don’t read into that people!!!!!
Manasa
Â
Sent: Friday, January 23, 2015 10:03 AM
To: Vantage
Â
Yes "everything" is possible, it just depends on how much effort (read money) you want to put into it. You can bring a data view for the jobs into the Project easy enough. Bu to make those views editable you'll have to do some trickery which is fairly advanced. But in short yes it can be done though it may require someone with some epicor coding experience
Â
Â
Â
Â
Â
Â
On Fri, Jan 23, 2015 at 10:54 AM, Manasa Reddy mreddy@... [vantage] <vantage@yahoogroups.com> wrote:
Â
Anyone using Projects in Epicor ever create a new tab under Jobs, for instance? I want to set up some fields based on a job associated in Project and fill out the new sheet. Yes we will have multiple jobs.
Is this possible? If I try to do it through the sheet wizard, it does not look like it is possible!
Manasa
Â
Â
Â
Â
Â
Â
</div><div><div class="ygrps-yiv-1702823858h5"> <div style="color:#fff;min-height:0;"></div>
