If I had to do a report like this, I would write it from the job
information, grouping or filtering based on the specific project# I need.
It's going to be a bit of work to get what you want. But you should be able
to get there the long way. Depending on what info you need, report builder
may not be an option - you may have to go to crystal or Access where you can
do sub-reports / sub-queries.
