Progress Table Permissions
Bill -
Please contact me off list if you still need the documents to set up
security for V8 so that I can forward them directly to you.
Contrary to comments on this thread, security can be setup on the database,
tables & fields so as to not conflict with the Vantage or Vista UI.
Calvin
calvin@...
hoomail4me
Sent: Friday, June 08, 2007 12:06 PM
Subject: [Vantage] Re: Progress Table Permissions
I was looking for the same and just received what Epicor calls their
"Setting up ODBC for V800 (Progress Database)" KIT (file
v803odbcKit.rtf). This was not a KIT, just a document that describes
the basic ODBC setup and configuration. It did reference a SQL script
that was suppose to be in the KIT to make it easy to set the table
permissions for a user but it was not included and Epicor support says
that the instructions are in error - there isn't any script available.
By default, the mfgsys databases have permissions set for the
"sysprogress" user - wide open permissions. I would not want my
report writers to have wide open permissions to the databases through
ODBC. Setting up another user with reduced permissions is an absolute
must - READ only and no access to sensitive tables - payroll, etc..
Anyone have a script for the Vantage 8 schema? Without, it makes
setting permissions on the hundreds of tables very time consumming.
Bill
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Jason
Claggett" <jason@...> wrote:
> Experience has been, you really don't want to mess with changing the
> permissions on the database as it can wreak havoc on any and all custom
> reports, ODBC driver setup, etc. With that in mind, it can be done. Best
> thing to do is get the documentation straight from Epicor if you still
> want to do it.
> You should be able to control via domain/user authentication as well as
> through Vantage application.
> Thanks,
> Jason Claggett
> Microsoft Small Business Specialist
> MCP #3856159
> 2W Technologies, LLC
> 317.578.2393
> jason@...
Behalf
> Of sanfranc415
> Sent: Wednesday, June 06, 2007 6:36 PM
> Subject: [Vantage] Progress Table Permissions
> I've noticed that by default all the tables and fields in progress give
> read/write access to "*" Is there a way to change this without
> manually going to each table and changing the permissions?
> Thanks,
> --TJ
--TJ
want to do it.
Jason Claggett
MCP #3856159
317.578.2393
jason@...
Of sanfranc415
--TJ
Bill
> want to do it.
> Thanks,
> Jason Claggett
> MCP #3856159
> 317.578.2393
> jason@...
> Of sanfranc415
> Thanks,
> --TJ
Bill -
tables & fields so as to not conflict with the Vantage or Vista UI without
difficulty. I don't know why people do this, but the sysprogress UID & PWD
should NEVER BE SHARED. Do you share your System Manager password? If you
are adding users, add a user and set their security respectively. Rule of
thumb: never share administrative passwords!
Calvin
calvin@...
hoomail4me
Bill
> want to do it.
> Thanks,
> Jason Claggett
> MCP #3856159
> 317.578.2393
> jason@...
Behalf
> Of sanfranc415
> Thanks,
> --TJ
