Progress Program question
Todd,
I took your advice (mostly). I created the progress .p to run that does
the editing based on screen values. I then set the program to run as
part of the open for the VBForm. Now with a barcode, I can have them
scan the Tracking number, then scan a barcode to "verify" the tracking
number. That barcode contains an enter to leave the tracking number
field, a "V" to open the VBForm, an "O" to ok the VBForm and an "O" to
ok the header information. I threw in a couple of extra "O"s to be sure
screen lag does not create a problem.
With this process I feel it is automated enough and fast enough to not
cause a problem for shipping.
Thank you for the advice about using the VBForm.
Aaron
Sent: Tuesday, January 13, 2004 11:12 AM
Subject: RE: [Vantage] Progress Program question
* On a VBform screen you could scan the "large" number in then
have a button to populate the main screen field with the trimmed value.
In 6.0+ I believe the scan field and the button could reside on the main
screen - kind of a kludge but if FEDEX volume is not real high compared
to other methods it might be OK.
-Todd C.
Sent: Tuesday, January 13, 2004 9:55 AM
Subject: [Vantage] Progress Program question
Ok, trying to use progress to write to the DB.
I want to take a tracking number scanned from a FEDEX label into the
tracking number field and cut it down to the actual tracking number.
Apparently FedEx adds some "extra" data into their tracking number
barcode. UPS and DHL are direct scans, but FedEx seems to have 16
characters (of junk to me) and then the tracking number, and then 4 more
characters (of junk to me).
I was going to use code similar to below, but this can't be done at the
screen level because I can't find a way to customize the ship header
screen. I am left with triggering this with a global alert, therefore
forcing me to change the data contained in the field, not the screen.
Any suggestions?
inittraknum = getStringValue("Shiphead.TrackingNumber.SCRVALUE":U).
IF LENGTH(inittraknum) > 29
THEN DO:
newtraknum = SUBSTRING(inittraknum, 17, 12).
setStringValue("Shiphead.TrackingNumber.SCRVALUE":U, newtraknum).
END.
ELSE DO:
END.
Thanks for any help.
Aaron Hoyt
Vantage System Admin
Hittite Microwave Corporation
Any suggestions?
THEN DO:
END.
ELSE DO:
END.
Aaron Hoyt
On a VBform screen you could scan the "large" number in then have a button to populate the main screen field with the trimmed value. In 6.0+ I believe the scan field and the button could reside on the main screen - kind of a kludge but if FEDEX volume is not real high compared to other methods it might be OK.
-Todd C.
Any suggestions?
THEN DO:
END.
ELSE DO:
END.
Aaron Hoyt
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12cdnv5rd/M=267637.4116732.5333197.1261774/D=egroupweb/S=1705007183:HM/EXP=1074095731/A=1853619/R=0/*http://www.netflix.com/Default?mqso=60178356&partid=4116732> click here
<http://us.adserver.yahoo.com/l?M=267637.4116732.5333197.1261774/D=egroupmail/S=:HM/A=1853619/rand=896549892>
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
Unfortunately, in 6.0 (where we are) this is not a customizable screen.
I was very excited when Epicor showed those off, but they turn out to be
few and far between. I would love to have a list of the screens that
are customizable, but no luck so far.
As far as the VB form goes, I could, but this would be three extra
clicks, and we ship several hundred shipments per day. As it is I am
asking a lot for the shipper to click into the header and scan the
number in.
I am still investigating just how much progress will let you do in a .p
file. I think I am going to be investigating the Set function.
Wish me luck,
Thanks Todd,
Aaron
-Todd C.
Any suggestions?
THEN DO:
END.
ELSE DO:
END.
Aaron Hoyt
ADVERTISEMENT
roupweb/S=1705007183:HM/EXP=1074095731/A=1853619/R=0/*http:/www.netflix.
com/Default?mqso=60178356&partid=4116732> &partid=4116732> click here
_____
Yahoo! Groups Links
_____
Yahoo! Groups Links
<http://docs.yahoo.com/info/terms/> Service.
