Progress .p question
As always I seemed to have completely missed a thought when I typed that.... But I got the answer I wanted and a bit more to chew on. Thanks!
TO clearify this is what I have and what I wanted.
This line is run in an On Leave statement for a configurator:
run //SERVERIPADDRESS/Epicor905/LOOKUPS/GO-PED/PED-ACC-PRICE.p(ChrSuffix,Substring(ChrPartNbr,1,1) + ChrCab + ChrDrawer,output DecAccPrice).
This is what the beginning of my .p File looks like:
/* Inputs DEFINED */
DEF INPUT PARAM ChrSuffix AS CHAR NO-UNDO.
DEF INPUT PARAM ChrPart AS CHAR NO-UNDO.
/* outputs DEFINED */
DEF OUTPUT PARAM DecAccPrice AS DECIMAL NO-UNDO
What I wanted was to how to add extra inputs and outputs to be optional...
But these lines give me what I think will work for what I was thinking of doing for inputs anyways Will give it a test:
> DEFINE INPUT PARAMETER p1 AS INT NO-UNDO.
> DEFINE INPUT PARAMETER p2 AS INT NO-UNDO.
> DEFINE OUTPUT PARAM pSum AS INT NO-UNDO.
> IF p1 = ? or p2 = ? THEN RETURN ERROR "Operands cannot be NULL".
--- In vantage@yahoogroups.com, "Mike Anstey" <manstey@...> wrote:
> You can update the dataset directly via a .p if you pass in the dataset
> shown at the top of the screen when you select run ABL program.
> (This example is for the Customer BO).
> Here is what you would put in the method (usually in the before slot)
> For you action you select "Execute ABL Code", when that screen comes up
> your will see the name of the dataset being used at the top.
> Make sure you click "Execute code below" and put in something like this:
> RUN ud/Bpm/yourprogram.p({&input-output_dataset_CustomerDataSet}).
> (replace the dataset with what you see at the top of the screen, BUT it
> should allways start with "&input-output_dataset_"
> And you then just replace the "CustomerDataSet" with the correct one.
> This will allow you to pass the dataset into your .p program and
> manipulate it any way you want.
> (the path I show is for unix and has to be accessible via your propath)
> windows has the slashes the other way I think.
> In your server side program you need to start with the following:
> {Bpm/Bpm.i &OBJECT_NAME=Customer &BPM_BO_SOURCE_BO=1}
> {core/CallContext/CallContext.i}
> {&define_input-output_parameter_dataset_for_CustomerDataSet} ( This
> is that same dataset you passed in on the method side, but note that
> this has &define_ in front of it)
> Finally you need to select the changed record and do whatever you want
> to the tt record:
> FIND FIRST ttCustomer WHERE ttCustomer.RowMod = "U" OR
> ttCustomer.RowMod = "A" NO-ERROR.
> IF AVAIL ttCustomer THEN
> DO:
> MESSAGE "ttCustomer.CustNum " ttCustomer.CustNum.
> ..... do stuff
> END.
> You can change or update ANY field on the file you are working with and
> it will get passed back to your screen and update the record when you
> save.
> And the best part? You NEVER have to open that method directive again.
> Just make your changes to the .p program and next time someone runs it,
> the changes will take effect.
> Of reptcon
> Sent: Friday, May 11, 2012 1:12 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Progress .p question
> /* put program sum.p on appserver */
> ASSIGN pSum = p1 + p2 NO-ERROR.
> IF ERROR-STATUS:ERROR THEN RETURN ERROR ERROR-STATUS:GET-MESSAGE(1).
> MESSAGE ("-- Sum.p of " + string(p1) + " + " + string(p2) + " = " +
> string(pSum)).
> RETURN "". /* The caller should check for RETURN-VALUE > "" to signify
> error or message for the user */
> Then in a directive - to call sum.p from Progress ABL
> Not being so careful to CAP keywords below ...
> Progress ABL, unlike C#, is case-insensitive unless you
> go out of your way to make it so.
> And you can freely abbrevieate keywords so long as you type
> enough to make them unique, e.g. def var for DEFINE VARIABLE.
> def var viTemp as int no-undo.
> def var op1 as int no-undo.
> def var op2 as int no-undo.
> def var i as int no-undo.
> repeat i = 1 to 10: /* time returns seconds since midnight */
> op1 = random(1,time).
> op2 = random(time,100000).
> if i = 10 then op2 = ?. /* NULL to force error condition */
> RUN cahTest.p (INPUT op1, INPUT op2, OUTPUT viTemp) no-error.
> /* INPUT is assumed and keyword is optional in parameters but OUTPUT or
> INPUT-OUTPUT is required when used. */
> /* Check to see if "RETURN ERROR" was passed back
> There are ways of making these messages appear to the user
> rather than in the appserver log as written below */
> if return-value > "" then message "RetVal:" + return-value.
> if error-status:error then do:
> message "Error:" + error-status:get-message(1).
> end.
> else message "Loop: " + string(i) + " Sum of " + string(op1) " + "
> string(op2) + " = " + string(viTemp).
> end. /* i loop */
> return.
> to call this from C# passing parameters
> is a bit more complicated,
> but I just wrote this in a customiztion of ud40
> with 3 epiText boxes and a button to trigger it.
> grr wish I could copy/paste the screen,
> will send via email if you want to see: cheins@...
> <mailto:cheins%40pny.com>
> note that these assemby references were required:
> - Epicor.Mfg.Core.BLConnectionPool
> - Epocir.Mfg.Core.Session
> - Progress.o4glrt
> they have to exists in your epicor client folder.
> plus this libarary reference at the top of the program:
> using Progress.Open4GL.DynamicAPI;
> private void epiButtonC1_Click(object sender, System.EventArgs args)
> // ** Place Event Handling Code Here **
> int viSum = getSumABL(Convert.ToInt32(epiTextBoxC1.Text),
> Convert.ToInt32(epiTextBoxC2.Text));
> epiTextBoxC3.Text = viSum.ToString();
> private int getSum(int p1,int p2)
> return p1 + p2;
> private int getSumABL(int p1, int p2)
> string sysReturn = "";
> int viSum = 0;
> Epicor.Mfg.Core.Session epiSession =
> ((Epicor.Mfg.Core.Session)oTrans.Session);
> Session ablSession = default(Progress.Open4GL.DynamicAPI.Session);
> try
> ablSession = epiSession.ConnectionPool.Get();
> ParameterSet parms = new ParameterSet(3);
> parms.setIntegerParameter(1, p1, ParameterSet.INPUT);
> parms.setIntegerParameter(2, p2, ParameterSet.INPUT);
> parms.setIntegerParameter(3, null, ParameterSet.OUTPUT);
> ablSession.runProcedure("cahTest.p", parms);
> sysReturn = (String)parms.ProcedureReturnValue;
> if (sysReturn == String.Empty) viSum = (int)parms.getOutputParameter(3);
> catch (Exception err)
> MessageBox.Show(err.ToString());
> finally
> if ((ablSession != null))
> epiSession.ConnectionPool.Release(ablSession);
> if (sysReturn != "") MessageBox.Show(sysReturn);
> return viSum;
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "Gibby" <guyguy50@> wrote:
> > I've on advice of some helpful people here have started using a lot of
> .p programs for many of my onleave queries and calculation as it allows
> so much more freedom for data manipulating and such. But coming from a
> C++ / PERL /PHP world to progress has got me asking where is this?
> > So my curious question of today is can I write a progress program,
> with using a run statement from my OnLeave statement and have optional
> inputs and outputs? I can't seem to find anything in the three main
> progress reference books that discuss this. Maybe I'm missing it, but it
> seems like it should be something that a 4th generation language should
> have. Then maybe it doesn't,so asking if anyones attempted this?
I've on advice of some helpful people here have started using a lot of .p programs for many of my onleave queries and calculation as it allows so much more freedom for data manipulating and such. But coming from a C++ / PERL /PHP world to progress has got me asking where is this?
So my curious question of today is can I write a progress program, with using a run statement from my OnLeave statement and have optional inputs and outputs? I can't seem to find anything in the three main progress reference books that discuss this. Maybe I'm missing it, but it seems like it should be something that a 4th generation language should have. Then maybe it doesn't,so asking if anyones attempted this?
MESSAGE ("-- Sum.p of " + string(p1) + " + " + string(p2) + " = " + string(pSum)).
RETURN "". /* The caller should check for RETURN-VALUE > "" to signify error or message for the user */
/* INPUT is assumed and keyword is optional in parameters but OUTPUT or INPUT-OUTPUT is required when used. */
end.
else message "Loop: " + string(i) + " Sum of " + string(op1) " + " string(op2) + " = " + string(viTemp).
end. /* i loop */
return.
- Progress.o4glrt
int viSum = getSumABL(Convert.ToInt32(epiTextBoxC1.Text), Convert.ToInt32(epiTextBoxC2.Text));
return p1 + p2;
int viSum = 0;
Epicor.Mfg.Core.Session epiSession = ((Epicor.Mfg.Core.Session)oTrans.Session);
try
finally
return viSum;
to the tt record:
DO:
..... do stuff
END.
save.
Of reptcon
string(pSum)).
end.
end. /* i loop */
return.
- Progress.o4glrt
return p1 + p2;
int viSum = 0;
try
finally
return viSum;
