I am working in a new location that has Vantage already installed. They
are on Vantage 5.1 and I get the following errors when opening the PET.
The PET does open but when it tries to connect the following error comes
up. I am not sure if the PET is something I can reload without
affecting Vantage itself.
An exception has occured in your application. If you click Continue,
the application will ignore this error and attempt to continue. If you
click quit, the application will be shut down immediately.
java.rmi.server.ExportException. Unable to create remote refence;
nested exception is:
java.rmi.server.Export.Exception. Listen failed on port: 0;
(When I hit Details on the error I get):
java.rmi.server.ExportException: Unable to create remote reference;
java.rmi.server.ExportException: Listen failed on port: 0;
java.net.SocketException: No available buffer space
at java/rmi/server/UnicastRemoteObject.exportObject
at java/rmi/server/UnicastRemoteObject.<init>
at com/progress/common/networkevents/EventBroker.<init>
at
com/progress/vj/explorer/ProgressExplorer.getClientEventBroker
at com/progress/vj/util/ProDialog.<clinit>
at com/progress/vj/util/ProDialog.getActiveProDlg
at com/progress/vj/util/ProMsgBox.show
at com/progress/vj/util/ProMsgBox.error
at com/progress/vj/explorer/ProgressServer.workingCallback2
at com/ms/lang/Delegate.dynamicInvoke0
at com/ms/wfc/ui/Control.invokeMarshaledCallback
at com/ms/wfc/ui/Control.wndProc
at com/ms/wfc/ui/Form.wndProc
at com/ms/wfc/app/Application$ParkingForm.wndProc
at com/ms/wfc/ui/Control$ControlWindow.wndProc
at com/ms/wfc/app/Window.callback
Thanks in advance,
Jim MacMillan
IT Manager
Synergy Manufacturing
Work-303-790-9200
Cell-505-453-8704
at
Thanks in advance,
Jim MacMillan
IT Manager
Work-303-790-9200
Cell-505-453-8704
