Progress BAM Blank Title 88251
Perfect! This worked great!!
Thanks a ton!
Of ksimon8fw
Sent: Friday, March 05, 2010 9:57 AM
Subject: [Vantage] Re: Progress BAM
Travis,
Not quite. Here's what I'd do. First, use displays in the program, such
as 'MESSAGE "inside of Checkbox IF statement". Then, you can check the
logs to see exactly where your logic isn't getting to. That will likely
help narrow it down a bit for you.
Second, your logic, may work, it's got some extra overhead in it which
you should remove. However, you're assigning the variable NewEmailBody
but never assigning that back to Email-Text. So, you may be building
that correctly but not movnig it back to the Email itself. However, you
don't need that variable anyway.
Here's the logic I would use, I've stripped out the long assign
statements, but this should work:
IF OrderHed.CheckBox02 = TRUE THEN DO:
FIND Customer WHERE ... NO-LOCK.
/* NOTE: you don't need the OrderDtl FIND here, take it out */
FIND ShipTo WHERE ... NO-LOCK.
MESSAGE "Inside of OH.CB02 if statement...".
ASSIGN Email-To = "tlate@..."
Email-Subject = "New Sales Order # " ...
Email-Text = "Items on order number " ...
FOR EACH OrderDtl WHERE ... NO-LOCK: /* Note the colon here */
MESSAGE "OrderDtl loop, line " + string(OrderDtl.OrderLine).
ASSIGN Email-Text = Email-Text + "~n~n...
END.
End.
/* If the order is not shipped */
ELSE DO:
RETURN "CANCEL SEND":U.
END.
One final note: you didn't do any error checking on some of your finds.
That's probably OK, you should never have an order without CUSTOMER. If
for some reason you had data corruption, you won't get the nice error
messages. I'm not sure if you're familiar with the "AVAILABLE"
statement, but you may consider that in there for proper error handling.
In other words:
FIND CUSTOMER ... NO-LOCK NO-ERROR.
IF AVAILABLE Customer THEN DO:
END.
ELSE DO:
ASSIGN Email-To = "support@....".
ASSIGN Email-Subject = "ERROR!!...".
ASSIGN Email-Text = "Customer not found on order ...".
END.
Hope that helps!
Kevin
"Late, Travis" <tlate@...> wrote:
> Kevin,
> I get no errors now, but when I receive the email there are still no
> order lines. Am I inserting this incorrectly? Below is what I have.
> {ud/GlbAlert.i &tablename = "OrderHed" }
> DEFINE VARIABLE NewEmailBody AS CHARACTER NO-UNDO.
> /*new email body*/
> THEN DO:
> FIND Customer WHERE Customer.Company = OrderHed.Company AND
> Customer.CustNum = OrderHed.BTCustNum NO-LOCK.
> FIND OrderDtl WHERE OrderDtl.Company = OrderHed.Company AND
> OrderDtl.Ordernum = Orderhed.OrderNum NO-LOCK no-error.
> FIND ShipTo WHERE ShipTo.Company = OrderHed.Company and ShipTo.CustNum
> OrderHed.CustNum and ShipTo.ShipToNum = OrderHed.ShipToNum no-lock
> no-error.
> IF OrderHed.Checkbox02 = TRUE
> THEN DO:
> + string(OrderHed.OrderNum)
> + "~n~n Order Number: " +
> STRING(OrderHed.OrderNum)
> + "~n Order Date: " + STRING(Orderhed.OrderDate)
> + "~n Your PO Number: " + STRING(Orderhed.PONum)
> + "~n Order Total: $" + STRING(Orderhed.CCAmount)
> + "~n~n Bill to: " + STRING(Customer.Name) + ", " +
> STRING(Customer.Address1) + ", " + STRING(Customer.City) + ", " +
> STRING(Customer.State) + ", " + STRING(Customer.ZIP)
> + "~n Ship to: " + STRING(ShipTo.Name) + ", " +
STRING(ShipTo.Address1)
> + ", " + STRING(ShipTo.City) + ", " + STRING(ShipTo.State) + ", " +
> STRING(ShipTo.ZIP)
> + "~n Expected Ship Date: " + (IF OrderHed.RequestDate = ? THEN "see
> below" ELSE STRING(orderhed.RequestDate)).
> End.
> FOR EACH OrderDtl WHERE OrderDtl.Company = OrderHed.Company
> AND OrderDtl.OrderNum = OrderHed.OrderNum
> NO-LOCK:
> /* Lines of Order */
> ASSIGN NewEmailBody = NewEmailBody
> + "~n~n~nOrder Lines:~n"
> + " Item " + STRING(OrderDtl.OrderLine) + ":~t"
> + STRING(OrderDtl.PartNum) + " " + STRING(OrderDtl.LineDesc)
> + ":~t" + STRING(OrderDtl.OrderQty) + " piece(s)"
> + (IF OrderHed.RequestDate = ? THEN ":~tShip By: "
> + STRING(OrderDtl.RequestDate) ELSE "")
> + "~n".
> END.
> End.
> ELSE DO:
> END.
Behalf
> Of ksimon8fw
> Sent: Thursday, March 04, 2010 4:16 PM
> Travis,
> I hadn't done the looping through the OrderDtl the way you did.
> Typically, this is the way I've done it:
> NO-LOCK:
> {insert your processing here}
> END.
> Note, you don't need a NO-ERROR on this, if it doesn't find any
> OrderDtl, it simply won't process the loop.
> Also, I hadn't done the embedded IF within an assign statement. Nice
> trick!
> Let me know if that works.
> Kevin Simon
> "Late, Travis" <tlate@> wrote:
> > Rob,
> > There are a ton of error messages, because I've been trying so many
> > things with this .p proragm . Here is a glimpse of what I have for
> > errors:
> > [10/03/04@15:10:14.196-0600] P-000812 T-000552 1 AS -- (Procedure:
> > 'db/trg/OrderHed/WRITE.P' Line:1227) ** Unable to understand after
> > "RequestDate))". (247)
> > \\Vantagetest\Epicor\mfgsys803\Server\ud\MBSalesOrder.p Could not
> > understand line 25. (198)
> > [10/03/04@15:10:52.969-0600] P-003016 T-003020 1 AS -- (Procedure:
> > "OrderDtl.PartNum)". (247)
> > understand line 26. (198)
> > [10/03/04@15:11:17.190-0600] P-001868 T-001052 1 AS -- (Procedure:
> > 'db/trg/OrderHed/WRITE.P' Line:1227) ** Incompatible data types in
> > expression or assignment. (223)
> > understand line 26. (196)
> > [10/03/04@15:12:25.698-0600] P-001868 T-001052 1 AS -- (Procedure:
> Behalf
> > Of Rob Bucek
> > Sent: Thursday, March 04, 2010 2:28 PM
> > Subject: RE: [Vantage] Progress BAM
> > What is your error message?
> > Rob Bucek
> > Manufacturing Engineer
> > PH: (715) 284-5376 ext 3111
> > FAX: (715)284-4084
> > <http://www.dsmfg.com/>
> > (Click the logo to view our site) <http://www.dsmfg.com/>
> > Behalf
> > Of Late, Travis
> > Sent: Thursday, March 04, 2010 1:17 PM
> > Subject: [Vantage] Progress BAM
> > I set up a .p program to send an email alert to a group designated
to
> > receive the email when a sales order is checked send email.
Everything
> > works fine with what I have below , but I want to add Order line
> details
> > to this .p program. I would like to add this, but always get an
error.
> > Any ideas how I can add the order lines to this .p?
> > Thanks in advance.
> > What I'd like to add
> > + "~n~n~nOrder Lines:~n".
> > FOR EACH OrderDtl of OrderHed no-lock:
> > Assign NewEmailBody = NewEmailBody
> > + "~n".
> > What I currently have working
> > /*new email body*/
> > THEN DO:
ShipTo.CustNum
> > no-error.
> > THEN DO:
> > ASSIGN Email-To = "tlate@ <mailto:tlate%40m-bco.com>
> > <mailto:tlate%40m-bco.com> "
> > STRING(ShipTo.ZIP)
> > End.
> > End.
> > ELSE DO:
> > END.
> > Travis Late
> > ERP Project Manager
> > M-B Companies, Inc
> > 1200 Park Street
> > Chilton, WI 53014
> > Phone: 920-898-1560 Ext.152
> > Cell: 920-960-0062
> > Email: tlate@ <mailto:tlate%40m-bco.com>
> > <mailto:tlate%40m-bco.com> <mailto:
> > tlate@ <mailto:tlate%40m-bco.com> <mailto:tlate%40m-bco.com> >
> > M-B Companies Confidentiality Notice:
> > This message is being sent by M-B Companies. It is intended
> exclusively
> > for
> > the individuals and entities to which it is addressed. This
> > communication,
> > including any attachments, may contain information that is
> proprietary,
> > privileged and confidential if you are not the named addressee; you
> are
> > not
> > authorized to read,print,retain copy or disseminate this message or
> any
> > part
> > of it.If you have received this message in error, please notify the
> > sender
> > immediately by email.
> exclusively for
> communication,
> proprietary,
> are not
> any part
> sender
exclusively for
communication,
proprietary,
are not
any part
sender
This message is being sent by M-B Companies. It is intended exclusively for
the individuals and entities to which it is addressed. This communication,
including any attachments, may contain information that is proprietary,
privileged and confidential if you are not the named addressee; you are not
authorized to read,print,retain copy or disseminate this message or any part
of it.If you have received this message in error, please notify the sender
I set up a .p program to send an email alert to a group designated to
receive the email when a sales order is checked send email. Everything
works fine with what I have below , but I want to add Order line details
to this .p program. I would like to add this, but always get an error.
Thanks in advance.
+ "~n".
/*new email body*/
THEN DO:
FIND ShipTo WHERE ShipTo.Company = OrderHed.Company and ShipTo.CustNum =
no-error.
THEN DO:
+ "~n Ship to: " + STRING(ShipTo.Name) + ", " + STRING(ShipTo.Address1)
STRING(ShipTo.ZIP)
End.
End.
ELSE DO:
END.
Travis Late
ERP Project Manager
M-B Companies, Inc
1200 Park Street
Chilton, WI 53014
Cell: 920-960-0062
Email: tlate@... <mailto:tlate@...>
I'm not familiar with the "of" command (I'm in 6.10 land and it may
exist - I just never used it). I've done something similar for receipts
of shortages where I send an alert to users to let them know the part
has arrived. Here is how I added the order detail:
ASSIGN NewEmailBody = NewEmailBody + "~nOrders:~n".
FOR EACH OrderRel WHERE (OrderRel.OpenRelease) AND
(OrderRel.PartNum = RcvDtl.PartNum):
ASSIGN NewEmailBody = NewEmailBody + "Order: " +
string(OrderRel.OrderNum) + " Line: " + string(OrderRel.OrderLine) +
" Release: " + string(OrderRel.OrderRelNum) + " Qty
Remaining: " +
string(OrderRel.SellingReqQty -
OrderRel.OurStockShippedQty - OrderRel.OurJobShippedQty) + "~n".
END.
So I would try changing your for each statement to something like:
FOR EACH OrderDtl where (OrderDtl.OrderNum = OrderHed.OrderNum no-lock:
Good luck,
Butch
Of Late, Travis
Sent: Thursday, March 04, 2010 11:17 AM
Thanks in advance.
+ "~n".
/*new email body*/
THEN DO:
no-error.
THEN DO:
ASSIGN Email-To = "tlate@... <mailto:tlate%40m-bco.com> "
STRING(ShipTo.ZIP)
End.
End.
ELSE DO:
END.
Travis Late
ERP Project Manager
M-B Companies, Inc
1200 Park Street
Chilton, WI 53014
Cell: 920-960-0062
Email: tlate@... <mailto:tlate%40m-bco.com>
<mailto:tlate@... <mailto:tlate%40m-bco.com> >
for
communication,
not
part
sender
Unfortunately that did not work. Not sure what the problem is with this.
Of Butch Menge
Sent: Thursday, March 04, 2010 1:31 PM
Remaining: " +
END.
Good luck,
Butch
Behalf
Of Late, Travis
Thanks in advance.
+ "~n".
/*new email body*/
THEN DO:
no-error.
THEN DO:
STRING(ShipTo.ZIP)
End.
End.
ELSE DO:
END.
Travis Late
ERP Project Manager
M-B Companies, Inc
1200 Park Street
Chilton, WI 53014
Cell: 920-960-0062
for
communication,
not
part
sender
What does your code look like with the "for each" lines in it?
Of Late, Travis
Sent: Thursday, March 04, 2010 12:56 PM
Behalf
Of Butch Menge
Remaining: " +
END.
Good luck,
Butch
Behalf
Of Late, Travis
Thanks in advance.
+ "~n".
/*new email body*/
THEN DO:
no-error.
THEN DO:
STRING(ShipTo.ZIP)
End.
End.
ELSE DO:
END.
Travis Late
ERP Project Manager
M-B Companies, Inc
1200 Park Street
Chilton, WI 53014
Cell: 920-960-0062
for
communication,
not
part
sender
for
communication,
not
part
sender
Rob Bucek
FAX: (715)284-4084
Of Late, Travis
Thanks in advance.
+ "~n".
/*new email body*/
THEN DO:
no-error.
THEN DO:
STRING(ShipTo.ZIP)
End.
End.
ELSE DO:
END.
Travis Late
ERP Project Manager
M-B Companies, Inc
1200 Park Street
Chilton, WI 53014
Cell: 920-960-0062
Email: tlate@... <mailto:tlate%40m-bco.com> <mailto:
for
communication,
not
part
sender
Rob,
errors:
'db/trg/OrderHed/WRITE.P' Line:1227) ** Unable to understand after --
Of Rob Bucek
Rob Bucek
FAX: (715)284-4084
Behalf
Of Late, Travis
Thanks in advance.
+ "~n".
/*new email body*/
THEN DO:
no-error.
THEN DO:
STRING(ShipTo.ZIP)
End.
End.
ELSE DO:
END.
Travis Late
ERP Project Manager
M-B Companies, Inc
1200 Park Street
Chilton, WI 53014
Cell: 920-960-0062
tlate@... <mailto:tlate%40m-bco.com> <mailto:tlate%40m-bco.com> >
for
communication,
not
part
sender
This is the code I have right now. I was using somebody else's code for
the OrderDtl Info so I'm not certain where to put that. All I want to do
is add the line information in the email. Seems like it should be easy
enough.
/*new email body*/
THEN DO:
no-error.
THEN DO:
STRING(ShipTo.ZIP)
End.
End.
/* If the order is not */
ELSE DO:
END.
Of Butch Menge
Sent: Thursday, March 04, 2010 3:02 PM
Behalf
Of Late, Travis
Behalf
Of Butch Menge
Remaining: " +
END.
Good luck,
Butch
Behalf
Of Late, Travis
Thanks in advance.
+ "~n".
/*new email body*/
THEN DO:
no-error.
THEN DO:
STRING(ShipTo.ZIP)
End.
End.
ELSE DO:
END.
Travis Late
ERP Project Manager
M-B Companies, Inc
1200 Park Street
Chilton, WI 53014
Cell: 920-960-0062
for
communication,
not
part
sender
for
communication,
not
part
sender
Travis,
I hadn't done the looping through the OrderDtl the way you did. Typically, this is the way I've done it:
NO-LOCK:
END.
Note, you don't need a NO-ERROR on this, if it doesn't find any OrderDtl, it simply won't process the loop.
Also, I hadn't done the embedded IF within an assign statement. Nice trick!
Kevin Simon
--- In vantage@yahoogroups.com, "Late, Travis" <tlate@...> wrote:
> Rob,
> errors:
> Of Rob Bucek
> Rob Bucek
> FAX: (715)284-4084
> Behalf
> Of Late, Travis
> Thanks in advance.
> + "~n".
> /*new email body*/
> THEN DO:
> no-error.
> THEN DO:
> STRING(ShipTo.ZIP)
> End.
> End.
> ELSE DO:
> END.
> Travis Late
> ERP Project Manager
> M-B Companies, Inc
> 1200 Park Street
> Chilton, WI 53014
> Cell: 920-960-0062
> for
> communication,
> not
> part
> sender
Kevin,
/*new email body*/
THEN DO:
no-error.
THEN DO:
STRING(ShipTo.ZIP)
End.
NO-LOCK:
+ "~n".
END.
End.
ELSE DO:
END.
Of ksimon8fw
Travis,
NO-LOCK:
END.
trick!
Kevin Simon
> Rob,
> errors:
Behalf
> Of Rob Bucek
> Rob Bucek
> FAX: (715)284-4084
> Behalf
> Of Late, Travis
details
> Thanks in advance.
> + "~n".
> /*new email body*/
> THEN DO:
> no-error.
> THEN DO:
> STRING(ShipTo.ZIP)
> End.
> End.
> ELSE DO:
> END.
> Travis Late
> ERP Project Manager
> M-B Companies, Inc
> 1200 Park Street
> Chilton, WI 53014
> Cell: 920-960-0062
exclusively
> for
> communication,
proprietary,
are
> not
any
> part
> sender
exclusively for
communication,
proprietary,
are not
any part
sender
Travis,
Not quite. Here's what I'd do. First, use displays in the program, such as 'MESSAGE "inside of Checkbox IF statement". Then, you can check the logs to see exactly where your logic isn't getting to. That will likely help narrow it down a bit for you.
Second, your logic, may work, it's got some extra overhead in it which you should remove. However, you're assigning the variable NewEmailBody but never assigning that back to Email-Text. So, you may be building that correctly but not movnig it back to the Email itself. However, you don't need that variable anyway.
Here's the logic I would use, I've stripped out the long assign statements, but this should work:
END.
End.
ELSE DO:
END.
One final note: you didn't do any error checking on some of your finds. That's probably OK, you should never have an order without CUSTOMER. If for some reason you had data corruption, you won't get the nice error messages. I'm not sure if you're familiar with the "AVAILABLE" statement, but you may consider that in there for proper error handling. In other words:
END.
ELSE DO:
END.
Hope that helps!
Kevin
> Kevin,
> /*new email body*/
> THEN DO:
> no-error.
> THEN DO:
> STRING(ShipTo.ZIP)
> End.
> NO-LOCK:
> + "~n".
> END.
> End.
> ELSE DO:
> END.
> Of ksimon8fw
> Travis,
> NO-LOCK:
> END.
> trick!
> Kevin Simon
> > Rob,
> > errors:
> Behalf
> > Of Rob Bucek
> > Rob Bucek
> > FAX: (715)284-4084
> > Behalf
> > Of Late, Travis
> details
> > Thanks in advance.
> > + "~n".
> > /*new email body*/
> > THEN DO:
> > no-error.
> > THEN DO:
> > STRING(ShipTo.ZIP)
> > End.
> > End.
> > ELSE DO:
> > END.
> > Travis Late
> > ERP Project Manager
> > M-B Companies, Inc
> > 1200 Park Street
> > Chilton, WI 53014
> > Cell: 920-960-0062
> exclusively
> > for
> > communication,
> proprietary,
> are
> > not
> any
> > part
> > sender
> exclusively for
> communication,
> proprietary,
> are not
> any part
> sender
