Cool. I'll try that thank you. -Jeff
--- In vantage@yahoogroups.com, "mmcwilliams22" <mmcwilliams22@...> wrote:
> Easiest way is to put a button right over one of the blank buttonsthen
> Private Sub btnEpiCustom1_Click(ByVal Sender As Object, ByVal Args As System.EventArgs) Handles btnEpiCustom1.Click
> Process.Start("PathToBTLabel")
> End Sub
> --- In vantage@yahoogroups.com, "jefferson112296" <jefferson112296@> wrote:
> > At this point, I just want the user to enter it into bartender at the time of printing. so I am just looking for a generic button to launch the bartender file. -Jeff
> > --- In vantage@yahoogroups.com, "mmcwilliams22" <mmcwilliams22@> wrote:
> > > No, all of it will have to be modified to meet your requirments.
> > > Will you be passing data or do you want the user to input?
> > > > Thanks for the example. This is pretty new to me so I'm not entirely sure I follow. Would I just copy and paste this code into the script editor and change the strPath and stParam2 to my own information?
> > > > > Here is an extended example.
> > > > > Private Sub btnOk_Click(ByVal Sender As Object, ByVal Args As System.EventArgs) Handles btnOk.Click
> > > > > Dim Printer As String = UDTagsForm.Session.UserID
> > > > > Dim UDTags As EpiDataView = Ctype(oTrans.EPiDataViews("UDTags"),EpiDataView)
> > > > > Dim TagNumber As String = UDTags.dataView(UDTags.Row)("Key1")
> > > > > Dim strPath As String = "C:\Progra~1\Seagull\BarTender\8.0\bartend.exe"
> > > > > Dim strParam As String = "/F=C:\Tags.btw /PRN= /P /X /?TagNumber="&TagNumber
> > > > > Dim strParam2 As String = strParam.Insert(20,Printer)
> > > > > Process.Start(strPath, strParam2)
> > > > > End Sub
> > > > > Here is what you are really concerned with.
> > > > > "strPath" is the path to your bartender program and parameter "strParam2" should contain any other parameters, like file name to open, printer, autoclose & query prompt input.
> > > > > > Does anyone know how to program one of the unused MES buttons to launch a bartender label file?
