Production Detail Report - Vantage 8.03.408
Has anyone experienced a problem previewing / printing the Production
Detail Report when you choose more than one job?
When you choose more than one job, all assemblies are chosen and it
errors out to:
Error Detail
Unexpected end of file has occurred. The following elements are not
closed: ReportDataSet. Line 1137, position 1.
Stack Trace
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String arg)
at System.Xml.XmlTextReaderImpl.Throw(Int32 pos, String res, String
arg)
at System.Xml.XmlTextReaderImpl.ThrowUnclosedElements()
at System.Xml.XmlTextReaderImpl.ParseElementContent()
at System.Xml.XmlTextReaderImpl.Read()
at System.Data.DataTextReader.Read()
at System.Data.XmlDataLoader.LoadData(XmlReader reader)
at System.Data.DataSet.ReadXml(XmlReader reader, Boolean
denyResolving)
at System.Data.DataSet.ReadXml(XmlReader reader)
at Epicor.Mfg.Lib.Report.EpiCrystalPushRpt.Process(ReportDocument
oRpt, String dataFile, String rptFile, DataSet dtsData)
at Epicor.Mfg.Lib.Report.EpiCrystalViewer.LoadReport(Object state)
This is NOT a customized RPT file, it is the standard ProdDtl.rpt.
Any help is appreciated.
Jim Moore
"This email message is for the sole use of the intended
recipient(s) and may contain proprietary and/or confidential
information for which such intended recipients(s) may have
an obligation to treat as proprietary. Any unauthorized review,
use, disclosure, or distribution is strictly prohibited. If you are
not the intended recipient, please contact sender by reply
email and destroy all copies of this e-mail."
