this is below the error code i get on my Process MRP. I dont see this when I run MRP during production hours. Could this be an issue with SQL or a time out on my App server. Epicor wants my logs but. But i don’t have the logs during this failure. I was wondering if anyone on here has seen this error message and is able to help. I can also wait till tonight on MRP failing. To see what happens.
Server Side Error
Server Side Exception
EpicorServerException
Correlation ID: 4438a869-42c0-41f9-bed1-9b713d01318c
Description: Execution Timeout Expired. The timeout period elapsed prior to completion of the operation or the server is not responding.
Inner Exception: The wait operation timed out
Program: System.Data.dll
Method: OnError
Original Exception Type: SqlException
SQL Line Number: 0
SQL Error Number: -2
Framework Method: InnerBroadcast
Framework Line Number: 63
Framework Column Number: 32
Framework Source: InnerBroadcast at offset 276 in file:line:column C:_Releases\ICE\UD10.2.500.8FW\Source\Framework\Epicor.System\AppServerNotification\DatabaseNotification.cs:63:32
Server Trace Stack: at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at System.Data.SqlClient.TdsParserStateObject.ReadSniError(TdsParserStateObject stateObj, UInt32 error)
at System.Data.SqlClient.TdsParserStateObject.ReadSniSyncOverAsync()
at System.Data.SqlClient.TdsParserStateObject.TryReadNetworkPacket()
at System.Data.SqlClient.TdsParserStateObject.TryPrepareBuffer()
at System.Data.SqlClient.TdsParserStateObject.TryReadByte(Byte& value)
at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady)
at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData()
at System.Data.SqlClient.SqlDataReader.get_MetaData()
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString, Boolean isInternal, Boolean forDescribeParameterEncryption, Boolean shouldCacheForAlwaysEncrypted)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, Boolean inRetry, SqlDataReader ds, Boolean describeParameterEncryptionRequest)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean& usedCache, Boolean asyncWrite, Boolean inRetry)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior, String method)
at System.Data.SqlClient.SqlCommand.ExecuteReader()
at Epicor.AppServerNotification.DatabaseNotification.InnerBroadcast() in C:_Releases\ICE\UD10.2.500.8FW\Source\Framework\Epicor.System\AppServerNotification\DatabaseNotification.cs:line 63
at Epicor.AppServerNotification.DatabaseNotification.Broadcast() in C:_Releases\ICE\UD10.2.500.8FW\Source\Framework\Epicor.System\AppServerNotification\DatabaseNotification.cs:line 36
at Epicor.Hosting.CallContext.Create(Operation op) in C:_Releases\ICE\UD10.2.500.8FW\Source\Framework\Epicor.Ice\Hosting\CallContext.cs:line 134
at Ice.Security.AuthorizationManager.CheckAccess(OperationContext operationContext, Message& message) in C:_Releases\ICE\UD10.2.500.8FW\Source\Framework\Epicor.Ice\Security\AuthorizationManager.cs:line 82
Inner Trace:
