Process Log File paths - Referenced to Server or Client?
Some processes allow you to specify a log file name and path - like Bulk Address Validation (shown below)
Is the path with respect to the App Server or the client?
For example, if i enter “C:\BAV.csv”, is that the App Server’s “C:” drive or the client’s?
And if the log file can’t be created - like when the App Server doesn’t have access to resource - it doesn’t appear to generate an error. The process runs, but you’ll have no log file. Or does it place the log file somewhere where it does have access?
App server I think; look under
\\appserver\c$\EpicorData\Companies\YourCompany\Log
Check the option called “Server File Download” within E10 itself. It was probably put in for cloud customers, but works well for on premise as well.
Where about is that setting?
EDIT
Never mind, I see it. It’s a process, not a setting.
