Jose C Gomez
T: 904.469.1524 mobile
On Thu, Sep 15, 2016 at 9:23 AM, Stephen Freeman stephenf@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p>
In 9.05.702.A in the Issue Material module I added a custom button to call a Custom Module using the UD100 table for its data. Module works fine in 905. We uplifted a test database to 10.1, we get the below error. I exported the customized Issued Material module and edited the xml. I changed, Erp.UI.UD100Entry to Ice.UI.UDEntry and reimported,  but did not get the desired results. It was like it pulled up a base UD100 customizatoin without any of my custom code. I think I need to manually edit the xml and reimport to fix this but I don't know what. Any ideas?
Message:Â The assembly 'C:\ProgramData\Epicor\ corperp04-808\3.1.400.0\ASPI\ shared\CustomDLLs\Erp.UI. UD100Entry' could not be found.
Program:Â Epicor.ServiceModel. dll
Method:Â GetFileNameToUseFromId entifier
Â
</div> <div style="color:#fff;min-height:0;"></div>
