Priority Dispatch
In report builder you can create a priority dispatch by:
Master table = JobOper
Join to the JobOper from JobOper using Alias name of JobOper2, Company =
Company, job = job.
Now for each JobOper record you will get all the operations for the job.
Add in the filter JobOper.OprSeq > JobOper2.OperSeq.
Now for each JobOper record you will get just prior operations.
Display your JOBOPER on a GROUP FOOTER and JobOper2 on the record line.
You will turn off the record line when finished unless you want to see all
prior operaitons.
Create calculated fields for information you need from a prior operation
using the PREVIOUS command.
Prior_Qty_Complete = PREVIOUS(JobOper.QtyCompleted)
You can even look back two operations:
PREVIOUS(PREVIOUS(JobOper.QtyCompleted))
I my company if the prior operation is a 15 minute task like WASH parts we
look back two operations to see if the parts are on their way.
Have fun.
Patrick Winter
From: melmike13 <mikeg.ptc@...> [mailto:mikeg.ptc@...]
Sent: Monday, February 03, 2003 4:44 PM
Subject: [Vantage] Priority Dispatch
Has anyone been able to write their own priority dispatch report? We
are running 5.1 and our "out of the box" report is getting confused
by our need to cascade operations--having more than one operation
running at a time. By having more that one operation open at a time
we are showing the job becoming available in the next operation step
that hasn't started yet. Often times this step is the final step,
and this wouldn't become valid until all of the parts have completed
on each of the previous steps. I guess that I'm looking for a filter
of some kind.
Mike Gilchrist
of some kind.
Mike Gilchrist
I have a PDR that I wrote in Access 2000. It uses ODBC SQL-92. If you want
it I will be more then happy to share. I will e-mail it directly to you. We
are on Vantage 5.1. Still not brave enough to go to 5.2.
Jeremy Leonard
IT Manager
K-T Corporation
Sent: Monday, February 03, 2003 5:44 PM
of some kind.
Mike Gilchrist
Thanks much. I would be happy to take a look at the file. Please
send it to me when you get a chance.
Mike Gilchrist
Perry Technology Corporation
Phone: (860)738-2525 Ext. 122
Fax: (860) 738-2426
Email: mikeg.ptc@...
--- In vantage@yahoogroups.com, "Leonard, Jeremy" <jleonard@k...>
you want
you. We
> Thanks
> Jeremy Leonard
> IT Manager
> K-T Corporation
> From: melmike13 <mikeg.ptc@s...> [mailto:mikeg.ptc@s...]
We
time
step
completed
filter
> of some kind.
> Thanks,
> Mike Gilchrist
must have
Builder and
