Printing (PDF/DXF/DWG) attachments (In Epicor) when printing Job
I would be interested in this also would it allow the attachemnts to be printed on different paper or easily modified for that we are trying to print out drawiings on 11X17
9.05.701 (In Implementation Phase)
Hello,
First post here. Happy to be a part of the group and get involved and help out where I can.
I do have a question regarding printing...
Is anyone handling automated printing of attachments to Jobs when
printing Job Travelers? If so, how are you handling this briefly?
I think APM+ has some option for this, but I'm not thinking we want to be scanning in prints and such. Is there any way when a traveler is printed or on the screen to print a traveler, that we could add a checkbox and logic to print all job attachments? Am I out of my mind?
Thanks!
Ryan Madej
We created an access database that does this by checking the Xref table that pertain to the JobNumber.
> Hello,
> Thanks!
> Ryan Madej
Hi Ryan,
In our case, we added a checkbox on the document type entry to indicate if the type should be printed with the job traveler.
Then we added a button to the job traveler screen with all the logic needed to retrieve and print each attachment related to the jobs.
> Hello,
> Thanks!
> Ryan Madej
Okay this sounds like money. You mind shooting me an email with a bit more in-depth of how you handle this. Not a BPM guru yet.
-- ryan@...
--- In vantage@yahoogroups.com, "hexadecimalman" <christian.duguay@...> wrote:
> Hi Ryan,
> > Hello,
> > Thanks!
> > Ryan Madej
Can you send me this information as well?
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of ryan_madej
Sent: Wednesday, July 10, 2013 3:43 PM
Subject: [Vantage] Re: Printing (PDF/DXF/DWG) attachments (In Epicor) when printing Job Travelers
-- ryan@...<mailto:ryan%40discountsteel.com>
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "hexadecimalman" <christian.duguay@...> wrote:
> Hi Ryan,
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "ryan_madej" <ryan@> wrote:
> > Hello,
> > Thanks!
> > Ryan Madej
We are trying to do the same thing.  Can you also send me an email with more info?
thanks.
---In vantage@yahoogroups.com, <christian.duguay@...> wrote:
Hi Ryan,
> Hello,
> Thanks!
> Ryan Madej
We want to do the same as well.  Please email or post "the logic needed to retrieve and print each attachment related to the jobs" in the job traveler.
Nick
E. 9.05.700b
thanks.
Hi Ryan,
> Hello,
> Thanks!
> Ryan Madej
We needed a way to specify which DocType should be printed with JobTraveler, so we added a “print with job traveler” checkbox on the Document Type maintenance screen. All Printing is done using Autovue, which will read command and file path in a text file generated by the custom code.
Using C# customization, I have added a button on the job traveler button which contains the following  logic.
First, When you use the filter to select the jobs you want on the JobTraveler Form, a dataview (joblist) gets populated with job and part number amongst other information.
I use the jobnum from this dataview to pass as parameter to the getbyID method of the JobEntryAdapter. Next, I loop through the JobHeadAttch table of this adapter to retrieve the value of xFileRefNum, which I will use as parameter for the GetByID method of XFileRefAdapter. Finally, as I don’t want to print all attachments, I will use the value of xFileRefAdapt.DocTypeID with the getByID method of the DocType adapter to verify if the checkbox01 field is true, if so,  the neede autovue command and  the file path from XFileRef.xFileName are written to the text file.
Same process repeats looping this time through the JobAsmblAttch table.
Finally, we programmatically start autovue, passing the text file path as argument.
Hope this helps and my explanation is clear enough.
Christian
Nick
E. 9.05.700b
thanks.
Hi Ryan,
> Hello,
> Thanks!
> Ryan Madej
Hi, did any of you ever get the directions/instructions/code for printing out attachments on Job Travelers?  If so, may I kindly ask if you could send them to me?
I actually have a need to print out part diagrams (.PDF docs) out of the Material Request Queue, but I'm finding that Crystal Reports does not support dynamically referenced PDF documents (just image files like jpg, bmp, etc.).
If I could see how the Job Travelers attachments are printed using your technique, it would help immensely.
Thank you in advance,
Mark
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Wednesday, July 10, 2013 4:50 PM
Subject: RE: [Vantage] Re: Printing (PDF/DXF/DWG) attachments (In Epicor) when printing Job Travelers
<div id="ygrps-yiv-420806543yiv5425287122ygrp-text">
  <div id="ygrps-yiv-420806543yui_3_16_0_1_1425065666913_27337">Can you send me this information as well?<br clear="none">
> Hi Ryan,
> > Hello,
> > Thanks!
> > Ryan Madej
</div>
<div class="ygrps-yiv-420806543qtdSeparateBR"><br><br></div><div class="ygrps-yiv-420806543yiv5425287122yqt7311969355" id="ygrps-yiv-420806543yiv5425287122yqt22657"><div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122 -- #ygrps-yiv-420806543yiv5425287122ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-mkp #ygrps-yiv-420806543yiv5425287122hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-mkp #ygrps-yiv-420806543yiv5425287122ads {
margin-bottom:10px;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-mkp .ygrps-yiv-420806543yiv5425287122ad {
padding:0 0;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-mkp .ygrps-yiv-420806543yiv5425287122ad p {
margin:0;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-mkp .ygrps-yiv-420806543yiv5425287122ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-sponsor #ygrps-yiv-420806543yiv5425287122ygrp-lc {
font-family:Arial;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-sponsor #ygrps-yiv-420806543yiv5425287122ygrp-lc #ygrps-yiv-420806543yiv5425287122hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-sponsor #ygrps-yiv-420806543yiv5425287122ygrp-lc .ygrps-yiv-420806543yiv5425287122ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122activity span {
font-weight:700;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122activity span span {
color:#ff7900;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122activity span .ygrps-yiv-420806543yiv5425287122underline {
text-decoration:underline;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 .ygrps-yiv-420806543yiv5425287122attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 .ygrps-yiv-420806543yiv5425287122attach div a {
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 .ygrps-yiv-420806543yiv5425287122attach img {
border:none;padding-right:5px;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 .ygrps-yiv-420806543yiv5425287122attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 .ygrps-yiv-420806543yiv5425287122attach label a {
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 .ygrps-yiv-420806543yiv5425287122bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 .ygrps-yiv-420806543yiv5425287122bold a {
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 dd.ygrps-yiv-420806543yiv5425287122last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 dd.ygrps-yiv-420806543yiv5425287122last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 dd.ygrps-yiv-420806543yiv5425287122last p span.ygrps-yiv-420806543yiv5425287122yshortcuts {
margin-right:0;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 div.ygrps-yiv-420806543yiv5425287122attach-table div div a {
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 div.ygrps-yiv-420806543yiv5425287122attach-table {
width:400px;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 div.ygrps-yiv-420806543yiv5425287122file-title a, #ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 div.ygrps-yiv-420806543yiv5425287122file-title a:active, #ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 div.ygrps-yiv-420806543yiv5425287122file-title a:hover, #ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 div.ygrps-yiv-420806543yiv5425287122file-title a:visited {
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 div.ygrps-yiv-420806543yiv5425287122photo-title a, #ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 div.ygrps-yiv-420806543yiv5425287122photo-title a:active, #ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 div.ygrps-yiv-420806543yiv5425287122photo-title a:hover, #ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 div.ygrps-yiv-420806543yiv5425287122photo-title a:visited {
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 div#ygrps-yiv-420806543yiv5425287122ygrp-mlmsg #ygrps-yiv-420806543yiv5425287122ygrp-msg p a span.ygrps-yiv-420806543yiv5425287122yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 .ygrps-yiv-420806543yiv5425287122green {
color:#628c2a;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 .ygrps-yiv-420806543yiv5425287122MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 o {
font-size:0;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122photos div {
float:left;width:72px;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122reco-category {
font-size:77%;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122reco-desc {
font-size:77%;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 .ygrps-yiv-420806543yiv5425287122replbq {
margin:4px;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-mlmsg select, #ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 input, #ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-mlmsg pre, #ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 code {
font:115% monospace;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-mlmsg #ygrps-yiv-420806543yiv5425287122logo {
padding-bottom:10px;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-msg p#ygrps-yiv-420806543yiv5425287122attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-reco #ygrps-yiv-420806543yiv5425287122reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-sponsor #ygrps-yiv-420806543yiv5425287122ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-sponsor #ygrps-yiv-420806543yiv5425287122ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-sponsor #ygrps-yiv-420806543yiv5425287122ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-text {
font-family:Georgia;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-text tt {
font-size:120%;}
#ygrps-yiv-420806543 #ygrps-yiv-420806543yiv5425287122 #ygrps-yiv-420806543yiv5425287122ygrp-vital ul li:last-child {
border-right:none !important;}
