Printing Landscape to Zebra Label Printer
It has been a few years since I used a Zebra printer, but I vaguely
remember having to do some setup on the printer itself in order to get
my labels to print.
Regards,
Linda
Of homestyleindustries
Sent: Monday, March 01, 2010 1:01 PM
Subject: [Vantage] Re: Printing Landscape to Zebra Label Printer
Have you tried setting up the printer in the Printer Maintenance under
Company Maintenance. I see in the setup there is a checkbox for
landscape. Not sure if the Zebra is setup to be a network printer (or
even if it can be setup as a network printer), but it is worth a shot.
melissa hietala <kevmel822@...> wrote:
> Hello All,
> I have a couple of labels setup to print from Vantage to a zebra label
printer. I am able to print to to this label printer in portrait
orientation with no issues. However, I can't get the labels to print in
landscape no matter what I do!
> A few of the settings I have are as follows:
> 1) - In the crystal report, under page setup I have the orientation
set to landscape.
> 2) - In the crystal report, under page setup and the printer button,
and then properties button, I have the "Paper Layout" set to landscape.
> 3) - Under the settings for the printer, under printing preference I
have the paper layout set to landscape.
> 4) - Under the settings for the printer, under the printing Defaults
button I have the paper layout set to landscape.
> Anybody come across issues like this before? What am I missing!?!?!
> Thanks,
> Dustin Biniek
Hello All,
I have a couple of labels setup to print from Vantage to a zebra label printer. I am able to print to to this label printer in portrait orientation with no issues. However, I can't get the labels to print in landscape no matter what I do!
1) - In the crystal report, under page setup I have the orientation set to landscape.
2) - In the crystal report, under page setup and the printer button, and then properties button, I have the "Paper Layout" set to landscape.
3) - Under the settings for the printer, under printing preference I have the paper layout set to landscape.Â
4) - Under the settings for the printer, under the printing Defaults button I have the paper layout set to landscape.
Dustin Biniek
To get my labels to print "landscape" I designed them that way in ZebraDesigner. There is a "Label Setup" option under File. Look at the properties (I think) there is a place to set the size of the label and you can design it in "portrait" mode then rotate it 180 degrees.
Hope this makes some sense. It sounds like the only thing you haven't tried is to design the label in a "landscape" layout.
Nancy
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of melissa hietala
Sent: Thursday, February 25, 2010 12:14 PM
Subject: [Vantage] Printing Landscape to Zebra Label Printer
Hello All,
Dustin Biniek
We have apm and use it to e-mail po's as well as packing slips and BOL's and invoices.
Thanx
Mark Trzaska
847-426-4560
Hello,
What Nancy says is right.
However, if you get you labels to print from crystal report the way you want them to, but are not able to do so from Vantage try this:
· Add /rpt to your Vantage shortcuts (this tells vantage to look at the reports configuration)
· If you still have trouble printing make sure your user is at least a power user on the computer. Sometimes with network printers the configuration is not saved to the printer on the local machine. Once the settings are saved and everything works the way you want it to, you can remove the users special permissions if you want.
Sébastien.-
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Dunn, Nancy
Sent: February-25-10 1:40 PM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Printing Landscape to Zebra Label Printer
Nancy
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of melissa hietala
Hello All,
Dustin Biniek
AVIS IMPORTANT: Cette transmission électronique est strictement réservée à l'usage de la (des) personne(s) à qui elle est adressée et contient des informations privilégiées et confidentielles. Toute divulgation, distribution, copie, ou autre utilisation de cette transmission par une autre personne est strictement prohibée. Si vous avez reçu ce courriel par erreur, veuillez s'il vous plaît en aviser immédiatement l'expéditeur par courriel et détruire tout exemplaire ou copie de la transmission originale.
WARNING: This electronic transmission contains confidential information, intended only for the person(s) named above, and is privileged. If you are not the intended recipient, you are hereby notified that any disclosure, copying, distribution, or any other use of this email is strictly prohibited. If you have received this transmission by error, please notify us immediately by return email and destroy the original transmission immediately and all copies thereof.
Sebastien,
Thanks for the response. When you say "Add /rpt to your Vantage shortcuts", what exactly do you mean? Can you tell me where and how I need to set this?
Dustin Biniek
Â
From: Sebastien Jean-Felix <sebastien.jean-felix@...>
To: "vantage@yahoogroups.com" <vantage@yahoogroups.com>
Sent: Thu, February 25, 2010 4:25:32 PM
Â
Hello,
Sébastien.-
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf Of Dunn, Nancy
Sent: February-25- 10 1:40 PM
To: 'vantage@yahoogroup s.com'
Nancy
From: vantage@yahoogroups .com<mailto:vantage% 40yahoogroups. com> [mailto:vantage@yahoogroups .com<mailto:vantage% 40yahoogroups. com>] On Behalf Of melissa hietala
To: vantage@yahoogroups .com<mailto:vantage% 40yahoogroups. com>
Hello All,
Dustin Biniek
____________ _________ _________ __
Have you tried setting up the printer in the Printer Maintenance under Company Maintenance. I see in the setup there is a checkbox for landscape. Not sure if the Zebra is setup to be a network printer (or even if it can be setup as a network printer), but it is worth a shot.
--- In vantage@yahoogroups.com, melissa hietala <kevmel822@...> wrote:
> Hello All,
> Thanks,
> Dustin Biniek
