Thanks, that ought to keep me busy for awhile. ;)
The problem is limited to Vantage's Progress based reports and I think I
concur with support that it is related to Progress' "least comon
denominator" strategy of writing for older drivers. I am pretty certain
that it is due to the message box that shows % completed not "hearing" the
printer/spooler say "I'm done!". So it sits at 99% forever and does not
close the progress (little p) window and this leaves the rest of Progress
(big P) hung. I'm not sure why it affects the mouse cursor until the task
is ended.
As soon as I can get at one of the users' PC when she leaves at 3pm (CST)
I'm going to install IE 6.0 because I have had other printing issues which
this resolved. Apparently IE 6.0 updates a lot of Windows stuff (like
MDAC). The downside is that the problem is not consistantly reproducable so
I'll have to wait sufficient time (a week?) and see if it stays gone and
even then not be totally sure it is fixed. The issue first came up with
Vantage 5.20.211 on Progress 9.1D. I'm going to do patch 305 this weekend.
-Todd C.
Sent: Thursday, January 02, 2003 2:33 PM
To: pml@...; vantage@yahoogroups.com
Subject: RE: [Vantage] Printing Hangs
At 01:00 PM 1/2/2003 -0600, you wrote:
strange PC hangs, here are some:
* Down grading the drivers is a good start (done that)
* Basic PC sanity checks, like ScanDisk or Norton Disk Doctor, and a virus
scan.
* Deleting all the contents of \VntgWork and the various temp directories
is a good idea (close Vantage 1st)
* Windows registry fixer-uppers, like WinDoctor in Norton System Works can
correct strange problems. Microsoft RegClean, too.
* Uninstall / Reinstall Progress & Vantage.
* Uninstall other printer drivers. Many of HP's ink jet drivers install
monitoring programs that run at windows' startup, and have been known to
affect other printers. Uninstall them, and check in the Start Menu ->
Startup and the various registry locations for them also.
* Any little "mini databases" or log files that windows maintains may
become corrupted and cause odd things to crash. Usually deleting (or more
safe - renaming or moving) the file and allowing it to be re-created from
scratch works. Any of the \Windows\*.PWL files are notorious. Also had
one with corrupted stuff in \Windows\AppLog -- a directory where windows
records frequently used EXE and DLL files in hopes of making the defrag
utility work better - del *.* fixed it.
* And [on more of a stretch with this one] -- Advertising spy-ware
installed by some applications monitors many windows and network activities
(often loading at boot time, and running even when the app' isn't in use)
and sometimes make other things crash. Plus, they're a damn invasive
nuisance. But, back at usaero I didn't have any way to prevent people from
downloading & installing free software, and this was occasionally the
culprit. LavaSoft's AdAware will remove much of it.
Any other "general purpose" fixes? I've been meaning to document a
standard check list for a long time.
-Wayne Cox
Twenty Three - Information Technology Consulting
828-685-2338
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=234081.2814790.4175286.1925585/D=egroupweb/S=17050071
83:HM/A=1327985/R=0/*http://ad.doubleclick.net/clk;4870024;7586687;x?http://
www.ameriquestmortgage.com/welcome.html?ad=Yahoo01>
<http://us.adserver.yahoo.com/l?M=234081.2814790.4175286.1925585/D=egroupmai
l/S=:HM/A=1327985/rand=142423506>
is ended.
-Todd C.
>Hey Wayne,Unfortunately, I don't have any sure-fire fixes or suggestions. But for
>Todd already tried the HP Series II driver and is still having the same
>problem. What else should he try?
scan.
-Wayne Cox
828-685-2338
ADVERTISEMENT
