Sounds like your database (or network) is running mighty slow in general. 45 to 50 seconds to launch Vantage is a LOONNGG time. No wonder a Print Preview takes a long time also, there are lots of records to recover many times. I would look into network issues.
Or you can try intalling a Vantage Client right on your server. To do this, map the network driver on the server just like you do for a regular workstation. Then run VantageClientSetup.exe like you would for a workstation. But BE SURE TO UNCHECK THE BOX THAT SAYS "INSTALL PROGRESS SOFTWARE". Progress is already installed on your server. You are basically just setting up the Vantage icons and entering a line in your Services file for Vantage.
After installing a Vantage Client on your server, run Vantage from the server and see if the login and print preview still takes a long time. If it does, then it is not a network issue and you have a couple options.
1. Fine tune your database parameters. Wayne Cox can give you some good pointers here, or you can call Epicor and they can help you too.
2. Buy a faster server.
I would say Option 1 is the better option.
Troy Funte
Liberty Electronics
Troy Funte
Liberty Electronics
----- Original Message -----
Sent: Monday, November 05, 2001 9:54 AM
Subject: [Vantage] Re: Print preview problem
Hi Terry, Thank you very much for response,
It takes almost a 45-50 seconds to launch Vantage at first on all my
computers, and when we select the print preview for any form from
vantage it takes almost a minute to bring the preview.
Yes i have Norton antivirus installed on the network but i already
exclude network and that drive from real time protection and select
that scan on create.Earlier vantage was taking more than a minute but
after i read from yahoo group that if we exclude vantage drive,the
issue will be resolved and of course it takes less time than that but
for forms it is same.
> How long does it take to launch Vantage in the first place? What
else is
> running on that computer? Any antivirus software that perhaps
needs some
> exclusions configured? Have you tried the task manager to see what
may be
> happening?
> Call me if you want to discuss.
> Terry L. Williams I.S. Manager Chipsco, Inc. 9936 Liberty St.
Ext.
> Meadville, PA 16335 p.8143336331 x236 f.8143372548 tlw@c...
> <mailto:tlw@c...> www.chipsco.com <http://www.chipsco.com/>
> -----Original Message-----
> From: sharma_nalini@y... [mailto:sharma_nalini@y...]
> Sent: Friday, November 02, 2001 2:11 PM
> To: vantage@y...
> no one knows has the answer or it is a stupid question.
> Yahoo! Groups Sponsor
> ADVERTISEMENT
<http://rd.yahoo.com/M=215002.1711356.3237013.1261774/D=egroupweb/S=17
050071
> 83:HM/A=847665/R=0/*http://ads.x10.com/?
bHlhaG9vbW9uc3RlcjcuZGF0=1004728286%
3eM=215002.1711356.3237013.1261774/D=egroupweb/S=1705007183:HM/A=84766
5/R=1>
must have
Builder and
> Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> <http://docs.yahoo.com/info/terms/> .
