Hello Epicor Community!
Sometimes our print preview gets stuck and people aren’t able to finish processing. I have noticed that it occurs when our Multi-Company Direct Server Process seems to be taking awhile or getting stuck. Would these two be related?
Also, when the Multi-Company process gets stuck, it usually shows an error like the one below. We are a cloud customer.
Thanks!
System.Data.Entity.Core.EntityCommandExecutionException: An error occurred while executing the command definition. See the inner exception for details.
—> System.Data.SqlClient.SqlException (0x80131904): Lock request time out period exceeded.
at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action1 wrapCloseInAction) at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose) at System.Data.SqlClient.TdsParser.TryRun(RunBehavior runBehavior, SqlCommand cmdHandler, SqlDataReader dataStream, BulkCopySimpleResultSet bulkCopyHandler, TdsParserStateObject stateObj, Boolean& dataReady) at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData() at System.Data.SqlClient.SqlDataReader.get_MetaData() at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString) at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite, SqlDataReader ds) at System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior behavior) at System.Data.Entity.Infrastructure.Interception.InternalDispatcher
1.Dispatch[TTarget,TInterceptionContext,TResult](TTarget target, Func3 operation, TInterceptionContext interceptionContext, Action
3 executing, Action3 executed) at System.Data.Entity.Infrastructure.Interception.DbCommandDispatcher.Reader(DbCommand command, DbCommandInterceptionContext interceptionContext) at System.Data.Entity.Core.EntityClient.Internal.EntityCommandDefinition.ExecuteStoreCommands(EntityCommand entityCommand, CommandBehavior behavior) ClientConnectionId:f8622b08-6654-4863-87f0-000bf49eac4a Error Number:1222,State:56,Class:16 --- End of inner exception stack trace --- at System.Data.Entity.Core.EntityClient.Internal.EntityCommandDefinition.ExecuteStoreCommands(EntityCommand entityCommand, CommandBehavior behavior) at System.Data.Entity.Core.Objects.Internal.ObjectQueryExecutionPlan.Execute[TResultType](ObjectContext context, ObjectParameterCollection parameterValues) at System.Data.Entity.Core.Objects.ObjectContext.ExecuteInTransaction[T](Func
1 func, IDbExecutionStrategy executionStrategy, Boolean startLocalTransaction, Boolean releaseConnectionOnSuccess)
at System.Data.Entity.Core.Objects.ObjectQuery1.<>c__DisplayClass41_0.<GetResults>b__0() at System.Data.Entity.Core.Objects.ObjectQuery
1.<System.Collections.Generic.IEnumerable.GetEnumerator>b__31_0()
at System.Data.Entity.Internal.LazyEnumerator1.MoveNext() at System.Linq.Enumerable.TryGetFirst[TSource](IEnumerable
1 source, Boolean& found)
at System.Linq.Enumerable.FirstOrDefault[TSource](IEnumerable1 source) at System.Data.Entity.Core.Objects.CompiledQuery.ExecuteQuery[TResult](ObjectContext context, Object[] parameterValues) at Epicor.Data.DBExpressionCompiler.GetResult[TDataContext,TQuery,TResult](Func
3 executeQuery, Cache cacheSetting, TDataContext dataContext, TQuery query) in C:_releases\ICE\ICE4.2.300.10\Source\Server\Framework\Epicor.System\Data\DBExpressionCompiler.cs:line 449
at Epicor.Data.DBExpressionCompiler.InvokeSingle[TDataContext,TQuery,TResult](Expression expression, Cache currentCacheSetting, Boolean cacheQuery, TDataContext dataContext, Func2 getDataCacheKey, Func
2 compileQuery, Func3 executeQuery) in C:\_releases\ICE\ICE4.2.300.10\Source\Server\Framework\Epicor.System\Data\DBExpressionCompiler.cs:line 310 at Epicor.Data.DBExpressionCompiler.<>c__DisplayClass56_0
4.b__0(TContext context, TArg1 arg1, TArg2 arg2) in C:_releases\ICE\ICE4.2.300.10\Source\Server\Framework\Epicor.System\Data\DBExpressionCompiler.Generated.cs:line 0
at Erp.Internal.SI.SIM130.RunProcess(Int64 instanceTaskNum, String outputFilename) in C:_releases\ERP\ERP11.2.300.0\Source\Server\Internal\SI\SIM130\SIM130.cs:line 250
at Ice.Hosting.TaskCaller.InnerExecuteTask(IceDataContext newContext) in C:_releases\ICE\ICE4.2.300.10\Source\Server\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 68
at Ice.Hosting.TaskCaller.ExecuteTask() in C:_releases\ICE\ICE4.2.300.10\Source\Server\Framework\Epicor.Ice\Hosting\TaskCaller\TaskCaller.cs:line 64
at Ice.Lib.RunTask.BpmFriendlyTaskLauncher.Run(String sessionIdPrefix, IceContext db, Action taskRunner) in C:_releases\ICE\ICE4.2.300.0\Source\Server\Services\Lib\RunTask\BpmFriendlyTaskLauncher.cs:line 63
at Ice.Services.Lib.RunTaskSvc.InnerRunTask(Int64 ipTaskNum, Boolean suppressTransaction) in C:_releases\ICE\ICE4.2.300.0\Source\Server\Services\Lib\RunTask\RunTask.cs:line 450
